Problem assigning users to VLANs
madan-sudhindra
Community Member
We have just implemented a Cisco wireless solution using Aironet 1230's and the Cisco ACS 3.3 (Eval).
We aer using PEAP as a method of authenticating the users trying to gain access to the wireless network.
The problem we are facing is that we are unable to assign the users to the requisite VLANs, using the ACS. We have followed the steps outlined on the Cisco site, but are getting confused as to what should the "vlan" attribute value be - should it be VLAN 1 or should it be the SSID to which the VLAN is mapped?
Please help us out
Thanks and regards
tcggg0
Level 3
Level 3
The VLAN's should be on the access points with one SSID assigned per VLAN. We use VLAN 1 for LEAP/PEAP, VLAN 2 for phones etc. We use ACS 3.2 for VLAN 1 and LEAP/PEAP authentication with AD.
