Problem in Auto-cad
mohammad saeed
Level 9
Level 9
Hi friend,
I have this problem while opening Auto-cad converted to png:
unable to convert the autocad file reason : error while opening the input file error code: -1012
what is the problem?
thanks
Scott Fella
Are you trying to add a floor plan to WCS/NCS/Prime? If so, maybe the file size is too big. You can try to convert it to another format.
-Scott
Scott Fella
Here is a Note from the guide:
Note If there are problems converting the auto-cad file, an error message is displayed. NCS uses a native image conversion library to convert auto-cad files into raster formats like PNG. If the native library cannot be loaded, NCS returns the "unable to convert the auto-cad file" message. If you receive this error, make sure all the required dependencies are met for the native library. To find any dependency problems, use ldd on Linux platforms. The following dlls must be present under the /webnms/rfdlls NCS installation directory: LIBGFL254.DLL, MFC71.DLL, MSVCR71.DLL, and MSVCP71.DLL. If dependency problems occurred, you may need to install the required libraries and restart NCS.
http://www.cisco.com/en/US/docs/wireless/ncs/1.0/configuration/guide/maps.html#wp1147486
-Scott
