radius auth interface for WLC
Vinayaka Raman
Level 6
Level 6
wlc mgmt interface,
wlc xyz interface---mapped to SSID which required radius auth...
which interface ip of WLC should be added as radius client on the radius server ?
Regards Vinayak
kcnajaf
Level 11
Level 11
Hi Vinayaka,
You should add the managment interface of WLC to the ACS server as aaa client.
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
Scott Fella
It depends now... In v7.4 it does have an entry for the WLAN also as a NAS Identifier. Also in v7.3 you can override the radius interface to use the dynamic interface for that WLAN.
By default you should use the management of the WLC. If on the WLAN SSID you check the Radius Server Overwrite Interface, it will use the interface applied to that WLAN.
-Scott
