Problem in connecting
fb_webuser
Level 11
Level 11
My mobile is not connecting to wifi (my router is Wag200G) but it's connecting to any other wifi, and any other device (mobiles and laptops) are connecting normally.Help!
Posted by WebUser Motassem Ja from Cisco Support Community App
aqjaved
Level 6
Level 6
To set up your WiFi network, tap the Menu Key > Settings >  Wireless & networks > WiFi settings. If WiFi is not checked, tap  WiFi to turn wireless on, and wait for your tablet to detect nearby  networks. Tap the name of your network and enter a security password, if  required.
WiFi networks that are configured as private or closed do not display  the network name on WiFi-enabled devices. To Join a closed or private  network, tap Menu Key > Settings > Wireless & networks >  enter the WiFi network name, security, and password.
fb_webuser
Level 11
Level 11
I tried that, didn't work also. The mobile can find the network but can't connect to it. Sometimes when I try to connect a "Authentication error occurred" message is shown.
