NTP and Timezones (GMT not correct)
i have a question about the Timezone settings in the WLCs.
We have serveral systems: 2100, 2500, 4400, 5500 series.
Problem occurs at firmware 7.0.98.0, 7.0.220.0, 7.0.240.0, 7.4.100.0
So i think this issue is not firmware or modelbased.
I have configured connection to NTP-server (windows).
The WLCs are getting the actual time from the server (when i change the time manually it's getting corrected, so it's working)
When the WLC is at default config and got the time from the NTP-Server at the location in the commands --> set time menu is set to -Select Location- the time is correct at UTC/GMT.
Delta is 0 0
When i change to location GMT+1 (Berlin, Amsterdam) the time is shown also correct (GMT+2 since we at daylight savings at the moment).
But we want to change all systems to have UTC/GMT timezone.
When i change the timezone back to GMT, it just gets back 1 hour (to GMT+1 instead of GMT).
What do i have to do to get the controller back to 'real GMT'.
For Example:
Time: UTC 9:15 AM
Timezone:
Time shown on WLC: 9:15 AM
--> correct
Time: UTC 9:15 AM
Timezone: GMT +1 (Berlin, Amsterdam)
Time shown on WLC: 11:15 AM
--> correct (since we are at daylight savings)
Time: UTC 9:15 AM
Timezone: GMT
Time shown on WLC: 10:15 AM
--> incorrect (looks like he tinks we have daylight savings at GMT Timezone).
Even after reboot no change
(Controller) >show time
Time............................................. Wed Sep 18 13:05:40 2013
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
    NTP Polling Interval.........................     3600
     Index     NTP Key Index     NTP Server      NTP Msg Auth Status
       1              0         10.96.75.77       AUTH DISABLED
Time............................................. Wed Sep 18 12:05:53 2013
Timezone location................................ (GMT) London, Lisbon, Dublin, Edinburgh
NTP Servers
(Controller) >
Maybe anyone can help me with this.
Thanks and Regards,
Gregor
6 Replies 6
Scott Fella
What I usually do is set the time and delta manually to the correct time, then I set NTP. If the time is off there, then I just trick the WLC and set it +1 or -1 to get it to the correct time.
-Scott
Hello Scott,
well, this would be the workaround if there is no 'real' solution for this, but some configuration for 32 controllers (even with prime i can't do this with templates).
I can't belive that the controllers for some reason don't know how to handle the NTP and timezone settings correctly ...
I just hope it doesn't change the time when the daylight savings ends and you have to make this settings twice a year.
Gregor
Well this has always been an issue and maybe I should of said that in my original post. Will time differ again with DST, probably. I just notice that time has to be close as possible before you use NTP as if the time is too far off, the WLC will not adjust.
-Scott
This is your issue.
Windows and NTP/SNTP ... They don't mix or don't work well.  You need to find an alternative source to synchronize NTP but don't use Windows.
Windows use Windows-based NTP and they are totally different to the NTP/SNTP standards.
Sadly Windows isn't the source of the issue.
I tried two unix timeservers as well and same result.
All other systems, Junipers, Cisco Switches, Checkpoint Firewalls, OpNet Appliances are working correctly with this servers.
Ok, I didn't read your thread properly.
I'll do what Scott has posted, I use the "Delta" option to +1 or -1 hour.
