Problem sending parameters to switch_url when using external login page with WLC 5500
gavin
Community Member
I am implementing radius authentication on my WLC 5508 and I have an external authentication page.
The WLC is correctly calling my external login url and is sending a switch_url parameter: http://1.1.1.1/login.html
My understanding is that I should post back to this switch_url with the radius username and password which I do (see html/javascript below).
However when I do this I just get presented with the default WLC authentication page (see attached - you normally see this when you go http://1.1.1.1/login.html).
According to all the literature that I have read this is how I should do it. What confuses me is:
  • The switch_url and the default WLC login page url are the same
  • One is supposed to send parameters (username and password) to what seems to be a static html page (login.html).
Any idea what I need to do to ensure that I get radius authentication at this point, and not get the WLC authentication page? Any help would be much appreciated.
Here is the html/javascript that I use to redirect to the switch_url:
<script type="text/javascript">
window.onload = function(){
document.forms['ciscologin'].submit()
</script>
<FORM name="ciscologin" method="post" ACTION="http://1.1.1.1/login.html">
<INPUT TYPE="hidden" NAME="username" SIZE="16" MAXLENGTH="15" VALUE="27835982456">
<INPUT TYPE="hidden" NAME="password" SIZE="16" MAXLENGTH="15" VALUE="27835982456">
<INPUT TYPE="hidden" NAME="buttonClicked" SIZE="16" MAXLENGTH="15" VALUE="0">
<INPUT TYPE="hidden" NAME="err_flag" SIZE="16" MAXLENGTH="15" VALUE="0">
<INPUT TYPE="hidden" NAME="err_msg" SIZE="32" MAXLENGTH="31" VALUE="">
<INPUT TYPE="hidden" NAME="info_flag" SIZE="16" MAXLENGTH="15" VALUE="0">
<INPUT TYPE="hidden" NAME="info_msg" SIZE="32" MAXLENGTH="31" VALUE="">
<INPUT TYPE="hidden" NAME="redirect_url" SIZE="255" MAXLENGTH="255" VALUE="">
<!-- <INPUT TYPE="hidden" NAME="redirect_url" SIZE="255" MAXLENGTH="255" VALUE="http%3A%2F%2Fshop.pnp.co.za"> -->
<INPUT TYPE="hidden" NAME="network_name" SIZE="64" MAXLENGTH="64" VALUE="">
<INPUT TYPE="hidden" NAME="network_name" SIZE="64" MAXLENGTH="64" VALUE="HIPPY">
</FORM>
d.friday
Level 8
Level 8
