Problem to connect directly to CISCO AP 1850
oneadnin1
I would like to know how to connect directly from my PC to Access point and set to static IP? My plan is to configured this access point as stand alone devices. Currently radio AP is disable so I cant connect directly through CiscoAirProvision SSID wireless.
Thank you
8 Replies 8
Sandeep Choudhary
You need to connect a console from your laptop to AP!!
How to setup: https://www.youtube.com/watch?v=XpStmxLBMd0
https://www.packet6.com/deploying-cisco-mobility-express/
Dont forget to arte helpful posts
I already connecting to console and connect to AP. But my problem is I dont know to create static IP address to AP. Is it this AP need to use Mobility Express? I cant donwload it from CISCO website.
yes it should be used as Mobiliy express .
Dont forget to rate helpful posts
how can I get mobility express? i cant download it because cisco say need Additional Entitlement Required .
You must have a valid service contract to download a Mobility express image from cisoc websie else you nee dto ask from your supplier he must provide you the required image.
Vengatesa Prasath
Hope you are not trying to use it as autonomous AP.
1850 AP can act as Mobility Express or lightweight AP.
Autonomous is not available in 1850 models.
********Please rate useful posts************
m.rana.ku
In the following video step by step process has been shown How to Configure Cisco AIRONET 3602i Autonomous/Standalone Access Point using GUI with WPAv2 Authentication Key.
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://youtu.be/AwuWsGGofT4
Configuring Aironet Access Point with WPAv2 Authentication in GUI :
1. In Easy Setup
Under Network Configuration
Edit AP hostname, Static IP, Subnet mask and Default Gateway
Under In Radio Configuration
Create SSID name WLAN_New under Radio 2.4GHz and select Broadcast SSID in Beacon
2. Apply Encryption Modes to AES CCMP
3. Enable WPAv2 and apply WPA Pre-shared Key: to SSID
4. Enable Wireless Radio Interface (Radio0-802.11N2.4GHz/ Radio1-802.11N5GHz) UP
5. Save the configuration
6. Finally check the SSID Wi-Fi connection, Security Key, IP address and browsing through internet
Configure_Cisco_AP #Standalone_GUI #IT_Support_People IT Support People Facebook Page: https://www.facebook.com/IT_Support-PeopleDesktop-Support-111268543923018 Link for Other Related Videos: Configuring Cisco Router to Access Internet through ISP Home router: ...
m.rana.ku
In the following video step by step process has been shown How to Configure Cisco AIRONET 3602i Autonomous/Standalone Access Point using CLI with WPAv2 Authentication Key.
https://www.youtube.com/watch?v=JkUfTXuwj2U
============ For 2.4 GHz Radio Interface ============
Step 1: Access Cisco AP|Reset AP| Assign static IP for BVI1 Interface |Default-gateway IP
ap>enable
Password: Cisco [Cisco AP default Password]
## Reset the Access Point with pressing and holding mode button ##
ap#configure terminal
ap(config)#interface bvI 1
ap(config-if)#ip address 192.168.2.4 255.255.255.0 [According to my network setup]
ap(config-if)#exit
ap(config)#ip default-gateway 192.168.2.1 [According to my network setup]
Step 2: Creating SSID | Authentication | Applying WPAv2 Authentication
ap(config)#dot11 ssid Cisco_WLAN [ Create SSID named Cisco_WLAN]
ap(config-ssid)#guest-mode [Broadcast SSID]
ap(config-ssid)#authentication open [allows any device to authenticate]
ap(config-ssid)#authentication key-management wpa version 2 [Applying WPAv2 Authentication]
ap(config-ssid)#wpa-psk ascii Cisco123 [Applying WPA Shared Key ]
ap(config-ssid)#exit
Step 3: Enable Encryption to 4.2GHz Radio interface | Apply SSID to interface| Enable Radio Interface
ap(config)#interface dot11Radio 0 [Selecting 4.2 GHz Radio interface]
ap(config-if)#encryption mode ciphers aes-ccm [Enabling CIPHER AES-CCM Encryption to interface]
ap(config-if)#ssid Cisco_WLAN [Applying SSID to Radio interface]
ap(config-if)#channel least-congested [Selecting Channel type]
ap(config-if)#no shutdown [Finally Enabling the 4.2 GHz Radio Interface]
ap(config-if)#exit
ap(config)#exit
================ For 5 GHz Radio Interface =======================
ap(config)#dot11 ssid Cisco_WLAN 5GHz [ Create SSID named Cisco_WLAN 5GHz ]
Step 3: Enable Encryption to 5 GHz Radio interface | Apply SSID to interface| Enable Radio Interface
ap(config)#interface dot11Radio 1 [Selecting 5 GHz Radio interface]
ap(config-if)#ssid Cisco_WLAN 5GHz [Applying SSID to Radio interface]
ap(config-if)# channel 36 [Selecting Channel type]
ap(config-if)#no shutdown [Finally Enabling the 5 GHz Radio Interface]
ap(config-if)#exit
ap(config)#exit
