05-21-2008 07:14 AM - edited 07-03-2021 03:54 PM
Hi all,
I did the upgrade on Cisco Aironet 1200 to c1200-rcvk9w8-tar.123-11.JX1.tar realease by tftp web interface. After that I can't access the AP again. It seems rebooting all the time. The 3 leds are blinking change order and colors until all stay green and everything starts again. I tryed to reset the AP by mode button but it doesn't work.
Anyone could give me some help ???
05-21-2008 07:23 AM
The code you use is an LWAPP code... now you need a controller for the access point to connect to... a reset the AP to factory default (see here http://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html ) and use another IOS only code...
hth
Jerome
05-21-2008 02:06 PM
Thanks Jerome,
The problem was the tftp server, I changed the tftp server program and the restore from another image was ok !!!
