problem with Airlap 1522
sahar.co67
Hi i have a cisco air lap 1522 but i have problem with it! I cant use config command in cli ? And i cant assign ip address to ap please help me! Tnx
19 Replies 19
Stephen Rodriguez
You need a WLC for that AP to work.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
sahar.co67
Thanks for your response
I know but How i can access to wlc?
Sahar:
If you have  WLC then if the AP in same subnet as management WLC IP address it will automatically discover the WLC.
You need a DHCP ip address to be active so that the AP gets an IP address.
If you don't have a DHCP server and you need to assign a static ip then use these commands:
AP#capwap ap ip address
AP#capwap ap ip default-gateway
AP#capwap ap controller ip address
Reference: http://tiny.cc/1vkljw
note: use the word "lwapp" instead of "capwap" if "capwap" did not work.
Amjad
Rating useful replies is more useful than saying "Thank you"
btw, you need to add a mac filter for the AP on the WLC to work.
check this:  http://tiny.cc/5ykljw
sahar.co67
My problem is that i dont have WLC?
You can't use that ap without a wlc. So you either need to return that or purchase at wlc.
-Scott
sahar.co67
Thanks alot for your response How i can purchase that? Is it software or hardware?
sahar.co67
Please help me my friend i dont know what can i do with this device ?!!;(
Sahar: Who sold you this outdoor access point? Why did you get it if you don't exactly know how it can be used? shouldn't you know how to use it and what is needed to be bought with it before you get it? Without a controller this box you have is unusable.
Cisco wireless controller is a hardware that runs a software image. There are many falvors and the main difference is the number of access points that can be supported.
look here: http://www.cisco.com/en/US/products/ps6302/Products_Sub_Category_Home.html
Amjad
p.s: is it 1522 or 1252? confirm please.
sahar.co67
Please dont be angry with me!!!;(
Nobody told me to tl bought it our company bought it! And i wanna to solve this problem!
İts 1522 !
So WLC is hardware! And how we can buy it? And although what is the price of WLC?
İ'm very sorry to ask this stupid question ! İ feel sad;( sorry
Don't be sad. We are trying to help you.
You can ask in your neighbor about any cisco dealer in your country and ask him about the controller prices.
Thanks alot for friends attentions!
the controller is seprate from ap? it means that the hardware device separate from ap?
sahar.co67
Which WLC is suitable with this ap? Tnx
If you want to save some money, you can purchase a WLC2106 which is EOL. I you want something new and still supported, you can get a WLC2504.
-Scott
