problem with Airlap 1522
sahar.co67
Hi i have a cisco air lap 1522 but i have problem with it! I cant use config command in cli ? And i cant assign ip address to ap please help me! Tnx
19 Replies 19
Tnx! This wlc supported with air lap 1522? İt means that air lap can work with this WLC?
sahar.co67
One things i know that am i need wirelles control system(WCS) ? Or no the WLC is enough? Tnx alot
The WLC is enough. WCS is used for monitoring and for management. WCS is pretty useful if you have more than one WLC so you can manage and monitor all of them from one location. But if you have only one WLC then that is it. No need for WCS.
AP 1522 is supported with all WLCs.
Amjad
You want to say "Thank you"? Don't. Just rate the useful answers, that is more useful than "Thank you".
Rating useful replies is more useful than saying "Thank you"
sahar.co67
when i purchase WLC i should connect it with ap phisycaly? İt means with wire?
The AP should be able to reach the WLC. It is not necessary to connect it directly but they should be reachable to each other.
Check this config example, it should be useful for you:
http://tiny.cc/ot1mjw
Amjad
