Problem with AP 2802 fail to join WLC
cripy192
hello I have a problem.
I try to join an ap 2802 to a wlc 5520 but I can't do it I get the following error in AP
IN AP 2802:
show capwap ip config
IP Address : 192.168.240.234
IP netmask : 255.255.255.0
Default Gateway : 192.168.240.3
Primary controller IP : 192.168.240.3
Primary Boot Image : 17.6.1.13
Backup Boot Image : 17.8.0.144
in WLC:
Version: 8.2.170.0
IP: 192.168.240.3
5 Replies 5
Leo Laohoo
On the WLC, post the complete output to the following commands:
  1. sh sysinfo
  2. sh time
NOTE:  Do not post screenshots.
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.170.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... WLCNEW
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 192.168.240.3
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 315 days 10 hrs 57 mins 31 sec s
System Timezone Location......................... (GMT -5:00) Eastern Time (US a nd Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
show time
Time............................................. Thu Jan 7 18:11:39 2021
Timezone delta................................... 0:0
Timezone location................................ (GMT -5:00) Eastern Time (US and Canada)
NTP Servers
NTP Polling Interval......................... 600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
Look at the time and date of the logs from the AP.  They are wrong.
The controller has no NTP settings and the time-and-date of the WLC is also wrong.
Set up the correct time-and-date or enable NTP and the AP should start to join.
Make sure time and date of WLC is correct
Good luck
KB
Arshad Safrulla
APs that are upgraded to Release 17.6.x cannot join controllers that are running AireOS versions earlier than 8.10.162.0, 8.5MR8, or 8.5.176.2(IRCM).
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-6/release-notes/rn-17-6-9800.html#:~:text=Warning-,APs,-that%20are%20upgraded
You need to manually downgrade the AP via tftp by connecting a console if SSH access is not available. Check the compatibility matrix and download the correct code for your AP and then downgrade it manually.
archive download-sw /reload tftp://<TFTP_IP_ADDRESS>/<FILENAME.TAR>"
