Wireless AP's
kheentech
Community Member
I would like to know whether the ff: AP's could run on Autonomous mode bu either means of a firmware or other method and non reliance on the controllers.
AIR-CAP3602I-N-K9
AIR-CAP3602I-N-K9
AIR-CAP3602E-N-K9
AIR-CAP1552E-N-K9
thanks
Sent from Cisco Technical Support Android App
kheentech
Community Member
Thanks for clarrifying.
9 Replies 9
Scott Fella
Yes they can. The autonomous firmware for the 1550's is for surveying. Also note that autonomous code doesn't give you the features you get from a WLC like CleanAir or Mesh.
-Scott
WTF, Scott!
Someone gave you a "THREE" star for a correct answer????
(+5) for what yu deserve.
At least it wasn't a 1 star:)
-Scott
kheentech
Community Member
No problem
-Scott
kheentech
Community Member
Scott,
Sorry was not aware of the points system. 10 star and very much appreciate your responce. This has saved me alot of painkillers.
Thank you
Haha. No problem at least you used the rating system... others don't:)
-Scott
kheentech
Community Member
Thats the thing. I was not aware of the star systems, unless 3 stars given by default.
Anyway, you step up 5 knotches on my belt 🙂 thanks
yong53798
Community Member
painkillers tablets available over the counter without a prescription. It's one of a group of painkillers called non-steroidal anti-inflammatory drugs (NSAIDs) and can be used to: ease mild to moderate pain – such as toothache, migraine and period pain.
