03-02-2011 09:31 AM - edited 07-03-2021 07:54 PM
I have a problem with my link bridge point to point..same time the link go down for this link pass trafic of voice and data, maybe the link it s full for that reazon goes down .. I want to konw wich coul be the problem and if there is same tool that permit to measurement consumption of the Band Width
The model of my bridge is CISCO AIR-BR1310G-A-K9-R
Thank Marco.
03-03-2011 10:34 PM
"show log" on each bridge, to know the reason of the link going down
03-06-2011 05:19 PM
03-06-2011 11:36 PM
It sounds like the link drops because there are too many retransmissions not going through. Looking at it, I would say that you have many other wifi networks in the area that are interfering with your bridge link. Not much you can do about that.
try :
config t
int d0
packet retries 16 drop-packet
This command will avoid the link to go down if there is an interference problem. Now it will not mean it solves the problem (packets will still be dropped when too much interference) but at least the link will not go down all the time.
