Sample config for wireless
megatron
Community Member
Does anyone have a sample config for standalone Cisco AP1252 (Cisco IOS)  for AD Authentication for wireless ?
Appreciated your kind reply.
5 Replies 5
Nicolas Darchis
You can't integrate a 1250 autonomous with AD directly. You have to go through a radius server. Be it Cisco ACS or Microsoft IAS/NPS. From there, it's basic config like in config guide.
Hi Nicolas,
Thanks for your reply. I found out that I need to install the microsoft IAS and need to know how to configure on the Cisco AP1252 on authenticate via radius.
Pls advise. Tks
The short version :
in config terminal mode :
-radius-server host auth-port 1812 acct-port 1813 key 0
-aaa authentication dot1x eap_methods group radius
Then you need to configure your ssid for dot1x :
-dot11 ssid
-authentication open eap eap_methods
-authentication network-eap eap_methods
This is only the part needed for radius interaction. This assumes that you already configured your SSID with according WPA settings.
that's about it I think.
If you want info about more commands or so, just check out this link :
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b-chap11-authtypes.html#wp1002608
Hi Nicolas,
Attached is the sample config.
Pls review if it is correct as not familar with radius authentication
It's looking good.
