Problem With FlexConnect
rbarreir
Community Member
I have configured an AP using FlexConnect but clients get disconnected from it. When the AP was first configured and integrated to the WLC everything seems to be fine but after a while clients started to got disconnected. I reset the AP to its factory configuration and integrated again to the WLC. Again the clients could connect to that AP without problems but after a while they got disconnected.
I read that for some clients is recommended to clear the 'Learn client IP address option' under WLAN configuration. I tried that but it did not solve my problem.
The configuration for FlexConnect seems to be fine VLANS are mapped and I am using management port for WLAN.
rbarreir
Community Member
I was checking the logs and I think I found the issue: after the AP joins the controller, the controller constains it as a rogue AP
*spamApTask0: Jun 13 00:09:01.750: #LWAPP-1-AP_CONTAINED: spam_lrad.c:37697 AP APfc5b.394f.c4b5 is being contained on slot 0
Where APfc5b.394f.c4b5 is the AP that has joined the controller.
How can I change this behaviour? the AP is not listed under 'Malicious Rogue APs'
