06-11-2015 02:01 PM - edited 07-05-2021 03:23 AM
Hi Everyone,
Is it possible if i have single WAP and WLC to setup 2 SSIDs one for internal users and other for visitors?
Also i want that internal and Visitors should be on different subnets?
Mahesh
06-11-2015 02:09 PM
Yes, see below sample config to see if that helps
Here is AP configuration. SSID Name, vlan, password you can modify as necessary. I have assumed vlan 999 as AP management on 192.168.99.x/24, modify that as needed.
hostname AP-01
dot11 ssid SSID_A
vlan 10
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii <SSID_A_PASSWORD>
dot11 ssid SSID_B
vlan 20
authentication open
mbssid guest-mode
wpa-psk ascii <SSID_B_PASSWORD>
interface Dot11Radio0
encryption vlan 10 mode ciphers aes-ccm
encryption vlan 20 mode ciphers aes-ccm
mbssid
ssid SSID_A
ssid SSID_B
no shut
interface Dot11Radio1
channel width 40-above <- if 802.11n AP & you want to bond two 20MHz
mbssid
ssid SSID_A
ssid SSID_B
no shut
interface Dot11Radio0.10
encapsulation dot1Q 10
bridge-group 10
interface Dot11Radio0.20
encapsulation dot1Q 20
bridge-group 20
interface Dot11Radio0.999
encapsulation dot1Q 999 native
bridge-group 1
interface Dot11Radio1.10
bridge-group 10
interface Dot11Radio1.20
bridge-group 20
interface Dot11Radio1.999
bridge-group 1
interface GigabitEthernet0.10
bridge-group 10
interface GigabitEthernet0.20
bridge-group 20
interface GigabitEthernet0.999
bridge-group 1
interface BVI1
ip address 192.168.99.101 255.255.255.0
ip default-gateway 192.168.99.1
Here is the switchport configuration where this AP connects.
interface GigabitEthernet1/0/X description AP-01 switchport trunk native vlan 999 switchport trunk allowed vlan 10,20,999 switchport mode trunk spanning-tree portfast trunk
Rasika
*** Pls rate all useful responses ***
06-11-2015 02:11 PM
Sorry, I noticed you have WLC. Below config only applicable if it is Autonomous AP.
In WLC environment, you simply want to create two WLAN and map it to two different dynamic interfaces.
Rasika
06-12-2015 07:31 AM
Hi Rasika,
So i can create two WLAN ids in WLC via gui.
Sau i create ssid internal and visitors.
Now i have single WAP 1252 and WLC 4402 how do i map it to different dynamic inetrface?
Can you please explain in detail about mapping?
MAhesh
06-12-2015 01:18 PM
Hi Mahesh,
This post should help you on this
https://rscciew.wordpress.com/2014/01/22/configure-dynamic-interface-on-wlc/
Rasika
06-12-2015 06:12 AM
Yes it is possible.
In WLC scenario you use create the 2-WLAN on WLC and map it to 2 different Dynamic interfaces.
But in Stand alone AP where no involvement of WLC configuration are to be made on AP and still it is possible.
