Problem with LEAP and CSACS 3.0
jmanevski
I have simple WLAN with five laptops (with Cisco PCMCI350), one AP350 and CS ACS 3.0. I have problem that after successfully LEAP authentication, wireless clients (laptops) authenticate but not associate with AP. On the Status window from ACU there in the Server Based Authentication row stay Cell is Secure and in the WEP row stay Enabled. The LEAP authentication passes successfully.
ps Is the AP350 AAA Client or AAA Server when configure in the CS ACS 3.0 and laptops also. Are there AAA Client and I must them put in User Setup like separate users?
Where to find initial configurations for CS ACS 3.0 for one AP350 and five laptops with Cisco PCMCI350 (for LEAP authentication)?
If someone know something about that or links with this problems, please write.
Thanks.
derwin
Level 5
Level 5
To configure LEAP on the the AP then please see this link
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo_350/accsspts/ap350scg/ap350ch8.htm
The AP is a NAS in the ACS configuration
There is a small section in the above link that will give you the basic setting needed to configure the ACS server for LEAP. For further information you need to see the ACS documentation found here
http://www.cisco.com/warp/public/cc/pd/witc/ao1200ap/prodlit/wrsec_an.htm
For full details on all of the ACS not just the LEAP part please see http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/
David
