Wireless in car or trucks
ROLAND MARTI
Level 4
Level 4
We need a special solution for wireless in car or trucks.
Is it the LMC adapter the right product and what for antenas is it needed?
Whats the full name for LMC?
It's the LMC Carte the same as the PCMCIA Card?
Roland Marti
p.krane
Level 3
Level 3
Since there seems to be only one antenna for the LMC card according to this link http://www.cisco.com/warp/public/cc/pd/witc/ao340ap/prodlit/airoa_ds.htm I guess there are not many options for this. You should probably get with a Cisco Sales Representative to assist you with your implementation.
d-dobson
Actually There is a wide variety of mounting and antenna types by manufactures such as Maxrad. I can provide you with more specific info via email ddobson@cloudstreaminc.com
