problem with Multicast on ASA 7.2(3)
adowfille
Hi Pals. I ve multicast configured on 2 interfaces of ASA(no multicast router used)-with Multicast server(source) on one interface of asa and the client on another. The multicast works fine at first but becomes intermittent after sometime(stops and works again) for clients on the 2nd interface of the firewall.Clients on the same interface as multicast source are not experiencing this.Please help
gmarogi
Level 5
Level 5
Is there any error message thrown at the time of this issue?. If so, can you send me a snapshot of that full error message so that I will go through that error message and identify the root cause of the problem.
Gabriel,
Thanks, the issue is now fixed. This was a misposting. Please check under firewall forum.
Kind regards
