Problem with password expired in active directory with WLC and ACS
carlos_rinc
Hello
I have a network with a WLC 4400 with aps 1200,ACS and Active Directory server. The authentication is peap-MS-chapv2.
All works good but when the password experied in the active directory, a messege display in order to enter the new password. When the New password is writen there are not conection to the network and the messege display again.
Thanks for your help
I've the same problem with my VPN concentrator. I rsolved the problem with givig the domain before the username.
For exemple
username: mydomain/myusername
password: mypassword
Hope that help... How do you have configure it with you WLC?
Vincent
