Problem with VLANmapping after Upgrade to 8.2.100.0
rueckertd
after updating our WLC 7500 from version 8.0.100 to 8.2.100.0 funkioniert the VLAN mapping on the APs no longer reliable. This means that the client can authenticate the AP, then get an IP address from the DHCP server associated values. If we the AP group to add a new SSID, and then remove the communication works an uncertain time. After an undefined time the clients lose communication again and get no IP address assigned more. Why is that, and who has the same Problem?
Thanks!
Philip D'Ath
Yep, seen the issue many times in another software version.  Can't remember which one.  We are currently running 8.1.131.0 and I think that one is ok.
8.0.121.0 is a gold star release if you want a release which should be very solid (be careful if you are using very new access points though - they may not be supported).
8.2.100 is bleeding edge new, so you have to expect some problems.
