10-29-2012 03:22 AM - edited 07-03-2021 10:56 PM
Hello everyone,
I have a problem with my Cisco wifi.
Here at work i am using 2 Cisco 1100 series Aironet (811G) (intalled in august 2005)
Product informations :
| AIR-AP1121G-E-K9 | |
| Top Assembly Serial Number: | FCZ0921V07A |
| System Software Filename: | c1100-k9w7-tar.123-4.JA |
| System Software Version: | 12.3(4)JA |
| Bootloader Version: | 12.3(2)JA3 |
All I-phones 4S OS6 are kind of loosing connection, if i am using google i will be able to use it once but never twices, the second time google will always time out, but the users are still able to receive and send their emails so the connection is still up.
On the manager i can see every Iphone, and everything seems to be ok, the "secutrity" is a simple 128bits wep key and i have a macadress filter activated and finally the SSID is not broadcasted.
The iphones are working smoothly with any modern wifi.
So my questions are, is it a firmware problem? a configuration problem? or it is time to upgrade the hardware?
Thank you for any help you can provide.
10-29-2012 09:16 AM
Problem solved, i have a new wifi.
10-29-2012 10:21 AM
What was the fix?
10-30-2012 07:08 AM
Turning off the 2 Aironet and activating the router's wifi, this wifi is not powerfull enough to cover the whole office but for now this is more than enough.
