Block Inter-SSID communication
london.ism
Hi guys
I have a wireless network with LWAPPs and 1 WLC 5508. Does anyone know how to block communication between SSIDs (clients in different SSIDs bassically) and whether that is even possible from the controller?
I'd like to mention that communication between clients whithin the same SSID is already blocked.
Many thanks
Elena
Saravanan Lakshmanan
this can be done using acl on wlc.
Yeah you need to put a ACL on the wireless lan controller. There's no fancy button like same SS ID client blocking in the wireless controller today. But make sure the ACL is on the WLC.
Hi George
Thank you for the reply
I was hoping to avoid that. ACLs on the controller are done on the same principle as on any other Cisco equipment? As in define acls and apply them to interface? (in this case SSID). I think I need a reference document on how this is done, as in syntax and everything else... Does anyone know?
Thank you
Elena
