PROBLEM with WINDOWS 2000 clients
luponec
Community Member
I'm trying to built a Wireless LAN using Aironet AP 350 series. I'd like to use EAP-TLS with dynamic WEP key using x.509 certificates on the clients and a ACS 3.1 with RADIUS.
The clients that have WIN-XP work fine.
My clients with WIN2K pro SP3 and 802.1x fix can not be assiociated to the AP.
The configuration is the same for both kind of clients. The only difference is that while in W2K the management has taken by operative system and cisco client ACU both, in WIN-XP the connection is managed only by Windows.
Anyone can give me some hint about other fix needed or configuration checks to do ???
tnx to all in advance.
derwin
Level 10
Level 10
On the win2k clients what version
firmware
NDIS
ACU
What results do you get for the EAP diag on the AP ? This will show if it is a problem with your server or the client card/AP
tcannito
Community Member
I've the same problem with win2k sp4. No communication between the AP and the pcm350 client, so no debug possible.
It seem like the driver stop working as it try to access the MS 802.1x layer.
Does your problem was solved ?
