Problemas AP WLC9800
jecheverrif
Frequent Visitor
Frequent Visitor
Buenas tardes
tengo una controladora C9800 con 23 AP en ella, los AP son  c9120AXE-A, lo que pasa es que 21 de ellos se me conectan a la wlc sin problema y los otros 2 no, la razón por la que no se conectan es " Type of error that occurred last Image-Download" mi controladora esta en la version
Cisco Catalyst 9800-L wireless controller 17.9.4a
alguno me podria indicar que puede estar ocurriendo con estos 2 AP
Nota; los AP cuando se configuro la WLC se conetaro a ella sin problema, solo hace unos días que vienen con este inconveniente
Muchas gracias
jecheverrif
Frequent Visitor
Frequent Visitor
El AP debe descargar la imagen 17.9.4.27 pero se queda en la  17.6.4.56
Rich R
Review these guides:
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/220443-how-to-avoid-boot-loop-due-to-corrupted.html
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/221869-safely-upgrade-access-points-avoiding-i.html
And if necessary (should not be necessary if it still has a working bootable 17.6 partition):
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9120axi-access-point/217537-repairing-c9120-c9115-access-points-from.html
17.9.4.27 means you do not have the APSP installed - I highly recommend installing at least APSP6.  Refer to TAC recommended link below but be aware of CSCwj45141  which is an issue that started in 17.9.4APSP8  You might also want to consider upgrading to 17.12.3 which is supposed to have a more robust fix for the image download corruption issue.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
