Problems on Radio0 Interface
nunoscosta
Level 3
Level 3
I am receiving High Queue Drop Rate Packets Output on the Dot11Radio interface for AP1100 on the deveice fault manager - monitoring console.
What could be the problem?
I have the virtual interface radio down and the AP is on Root Mode.
Can i delete this interface? Can i disable it?
I using Vlans, one native and another for the users.
Why i need to use encapsulation dot1q on the radio interface if i do not need trunk on this interface? Can i just use the bridg-group without encapsulation?
Thank you very mush for your support,
Nuno Costa
wong34539
Level 11
Level 11
Are you seeing any CRC errors on the interface. CRC errors and PLCP errors can occur due to Radio Frequency interference. The higher the number of radios in a cell (APs, Bridges or Clients), higher are the chances for the occurrence of these errors. For more information read http://www.cisco.com/en/US/products/hw/wireless/ps5279/products_tech_note09186a0080508551.shtml#crcplcp
