problems with session duration for 1 client
lydia.walther
Level 3
Level 3
we have some problems with one of our wifi clients.
The wireless lan controller is a model 4402 with software version 6.0.196.0.
The access points are connected via mesh mode! The status seems to be stable (Uptime of two access points
in the third floor is about 10 days).
Normally we only provide one wireless network with WPA+WPA2 and WEB-Auth. But since two weeks there is a guest
who says he's beeing disconnected very often. Because we thought it would be a problem with the WEB-Authentication and his apple computer,
we set up a new wifi network with mac address filter. But the guest is still complaining about the connection.
In the wireless control system reports I can see, that there are often connections of this guest which has a session duration
of exactly "5 min 0 sec". But in the meantime there are also session durations of several hours.
(Session timeout is not enabled! User Idle Timeout is set to 3000 seconds and ARP timeout is 300 seconds)
In the old version of WCS there was given a "reason code" for the disassociation of clients, but in this version I can't
see something like that. (I upgraded the version this week.)
In the trap log of the controller there are only messages like "Client Association" and "Client Authenticated" for the concerned client, but no entrys
for disassociation or deauthentication.
Other guests do not have this problem. It's only one guest using two different computers (1 Apple, 1 Windows).
Affected is the guest who's living in the highest floor of the house. Other guests in the first floor do not have
problems. Could this really be a problem of the mesh mode? We never had a guest before with so big problems.
Where can I found the reason for the clients new authentication? What is happening after exactly 5 minutes?
Does anybody has an idea?
During we tested the wifi with our computers there were no problems although we were sitting in the highest floor. We will do an endurance test for some hours tomorrow.
Greetings Lydia
21 Replies 21
Scott Fella
Can you post the show WLAN
-Scott
thank you for your answer. Here is the output.
Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... mpids_gh
Network Name (SSID).............................. mpids_gh
Status........................................... Enabled
MAC Filtering.................................... Enabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  NAC-State...................................... Disabled
  Quarantine VLAN................................ 0
Number of Active Clients......................... 1
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ mpids_gh_if
WLAN ACL......................................... unconfigured
DHCP Server...................................... 192.168.243.1
DHCP Address Assignment Required................. Enabled
--More-- or (q)uit
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
--More-- or (q)uit
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      WPA2 (RSN IE).............................. Enabled
         Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
   CKIP ......................................... Disabled
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
--More-- or (q)uit
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Learn IP Address....................... Enabled
   Infrastructure MFP protection................. Disabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Band Select...................................... Enabled
Load Balancing................................... Enabled
Mobility Anchor List
WLAN ID     IP Address            Status
it would be better to have debug client < mac address of client > while the issue is happenning to figure out the reason of disconnectivity.
it worths to have the output of show network summary
Thank you.
Can you please tell me how to use the debug command?? I tried it in the morning, but it was not very succesfull.
(Cisco Controller) >show network summary
RF-Network Name............................. gaeste
Web Mode.................................... Disable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Mode..................... Disable
Ethernet Broadcast Mode..................... Disable
AP Multicast Mode........................... Unicast
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 3000 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Disable
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
Apple Talk ................................. Disable
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
802.3 Bridging ............................. Disable
IP/MAC Addr Binding Check .................. Enabled
(Cisco Controller) >debug client e8:39:df:84:8b:0c
(Cisco Controller) >show debug
MAC address ................................ e8:39:df:84:8b:0c
Debug Flags Enabled:
  dhcp packet enabled.
  dot11 mobile enabled.
  dot11 state enabled
  dot1x events enabled.
  dot1x states enabled.
  pem events enabled.
  pem state enabled.
  CCKM client debug enabled.
Scott Fella
For one, you should only use either WPA with TKIP or WPA 2 with AES. You have all enabled and Apple devices don't like that. So with your test, make sure you use WPA2/AES and test the client again.
-Scott
As yet the client was always connected with WPA2/AES with both computers - the apple and the windows machine. And the problem of disassociating is occuring on both computers.
Greetings Lydia
So if you setup the client with WPA2/AES, make sure WPA2/AES is only checked not all of them or a mixture of each. Also make the changes I suggested in the other post. I have a MacBook Pro and that is troublesome, but my iPhone and iPad is worse, that's how I know what works with these devices.
-Scott
Scott Fella
Also disable band select and load balancing as that's another reason these devices fail. I would also remove dhcp required also for now. If your test seems to work, then you can enable that, but only that and then make sure the device works fine.
-Scott
ok, thank you. we will try these things.
Greetings Lydia
I read it would be better to disable Aironet IE if there are apple Computers. What do you think about it? And is this effecting the mesh mode?
Greetings Lydia
It doesn't hurt. It doesn't affect my devices but I tend to not have that enabled anyways. The other stuff will affect your devices.
-Scott
Hello @all,
I made all the changes you said on friday. I disabled band select and load balancing, removed dhcp required. I only activated WPA2 with AES and disabled AIRONET IE. And I installed a further access point in the second floor of our guest house.
The problem of short session durations is still there on the two computers of our guest as well as on our test-macbook. We placed it in the neighbour apartment of the guest who's having problems. It was "online" since friday morning (we run a ping all the time). We can see some interrupts and sometimes the session duration is exactly 5 min 0 sec. (picture in attachment)
Greetings Lydia
debug client while the issue is happenning
I captured something with debug client. At this moment client had to build a new association.
In advance sorry for the long text.
(Cisco Controller) >*Mar 04 10:27:55.732: 00:1e:52:7d:e8:e7 Stopping retransmission timer for mobile 00:1e:52:7d:e8:e7
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c Association received from mobile on AP 00:1d:70:01:b5:a0
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c Applying site-specific IPv6 override for station e8:39:df:84:8b:0c - vapId 2, site 'default-group', interface 'mpids_gh_if'
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c Applying IPv6 Interface Policy for station e8:39:df:84:8b:0c - vlan 14, interface id 9, interface 'mpids_gh_if'
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c Processing RSN IE type 48, length 20 for mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Deleted mobile LWAPP rule on AP [00:1d:70:01:b7:f0]
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c Updated location for station old AP 00:1d:70:01:b7:f0-0, new AP 00:1d:70:01:b5:a0-0
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Change state to START (0) last state RUN (20)
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c 192.168.243.45 START (0) Initializing policy
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c 192.168.243.45 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c 192.168.243.45 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b5:a0 vapId 2 apVapId 2
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c apfPemAddUser2 (apf_policy.c:212) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b5:a0 from Associated to Associated
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c Stopping deletion of Mobile Station: (callerId: 48)
*Mar 04 10:43:45.412: e8:39:df:84:8b:0c Sending Assoc Response to station on BSSID 00:1d:70:01:b5:a0 (status 0)
*Mar 04 10:43:45.413: e8:39:df:84:8b:0c apfProcessAssocReq (apf_80211.c:4361) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b5:a0 from Associated to Associated
*Mar 04 10:43:45.416: e8:39:df:84:8b:0c 192.168.243.45 Removed NPU entry.
*Mar 04 10:43:45.425: e8:39:df:84:8b:0c Creating a PKC PMKID Cache entry for station e8:39:df:84:8b:0c (RSN 2)
*Mar 04 10:43:45.425: e8:39:df:84:8b:0c Adding BSSID 00:1d:70:01:b5:a1 to PMKID cache for station e8:39:df:84:8b:0c
*Mar 04 10:43:45.425: New PMKID: (16)
*Mar 04 10:43:45.425:      [0000] 1a 3a 8b 04 05 59 7f f2 71 cb 4c 32 9c c2 3e 4d
*Mar 04 10:43:45.425: e8:39:df:84:8b:0c Initiating RSN PSK to mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.425: e8:39:df:84:8b:0c dot1x - moving mobile e8:39:df:84:8b:0c into Force Auth state
*Mar 04 10:43:45.426: e8:39:df:84:8b:0c Skipping EAP-Success to mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.426: Including PMKID in M1  (16)
*Mar 04 10:43:45.426:      [0000] 1a 3a 8b 04 05 59 7f f2 71 cb 4c 32 9c c2 3e 4d
*Mar 04 10:43:45.426: e8:39:df:84:8b:0c Starting key exchange to mobile e8:39:df:84:8b:0c, data packets will be dropped
*Mar 04 10:43:45.426: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
        state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Mar 04 10:43:45.431: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.432: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.432: e8:39:df:84:8b:0c Received EAPOL-key in PTK_START state (message 2) from mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.432: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.432: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
        state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Mar 04 10:43:45.441: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.441: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.441: e8:39:df:84:8b:0c Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.441: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Mar 04 10:43:45.442: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b5:a0 vapId 2 apVapId 2
*Mar 04 10:43:45.442: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Mar 04 10:43:45.443: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Reached PLUMBFASTPATH: from line 4574
*Mar 04 10:43:45.443: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Adding Fast Path rule
  type = Airespace AP Client
  on AP 00:1d:70:01:b5:a0, slot 0, interface = 1, QOS = 0
  ACL Id = 255, Jumbo Frames = NO,
*Mar 04 10:43:45.443: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*Mar 04 10:43:45.443: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:43:45.446: e8:39:df:84:8b:0c 192.168.243.45 Added NPU entry of type 1, dtlFlags 0x0
*Mar 04 10:43:45.484: e8:39:df:84:8b:0c DHCP received op BOOTREQUEST (1) (len 324, port 1, encap 0xec03)
*Mar 04 10:43:45.484: e8:39:df:84:8b:0c DHCP selecting relay 1 - control block settings:
                        dhcpServer: 192.168.243.1, dhcpNetmask: 255.255.255.0,
                        dhcpGateway: 192.168.243.254, dhcpRelay: 192.168.243.1  VL
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP selected relay 1 - 192.168.243.1 (local address 192.168.243.1, gateway 192.168.243.1, VLAN 14, port 1)
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP transmitting DHCP REQUEST (3)
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP   xid: 0x3dd65115 (1037455637), secs: 0, flags: 0
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.243.1
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP   requested ip: 192.168.243.45
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP selecting relay 2 - control block settings:
*Mar 04 10:43:45.485: e8:39:df:84:8b:0c DHCP selected relay 2 - NONE
*Mar 04 10:43:45.486: e8:39:df:84:8b:0c DHCP received op BOOTREPLY (2) (len 548, port 0, encap 0x0)
*Mar 04 10:43:45.487: e8:39:df:84:8b:0c DHCP sending REPLY to STA (len 418, port 1, vlan 252)
*Mar 04 10:43:45.487: e8:39:df:84:8b:0c DHCP transmitting DHCP ACK (5)
*Mar 04 10:43:45.487: e8:39:df:84:8b:0c DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*Mar 04 10:43:45.487: e8:39:df:84:8b:0c DHCP   xid: 0x3dd65115 (1037455637), secs: 0, flags: 0
*Mar 04 10:43:45.487: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:43:45.487: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 192.168.243.45
*Mar 04 10:43:45.487: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*Mar 04 10:43:45.487: e8:39:df:84:8b:0c DHCP   server id: 1.1.1.1  rcvd server id: 192.168.243.1
*Mar 04 10:45:31.697: e8:39:df:84:8b:0c Reassociation received from mobile on AP 00:1d:70:01:b7:f0
*Mar 04 10:45:31.697: e8:39:df:84:8b:0c Applying site-specific IPv6 override for station e8:39:df:84:8b:0c - vapId 2, site 'default-group', interface 'mpids_gh_if'
*Mar 04 10:45:31.697: e8:39:df:84:8b:0c Applying IPv6 Interface Policy for station e8:39:df:84:8b:0c - vlan 14, interface id 9, interface 'mpids_gh_if'
*Mar 04 10:45:31.697: e8:39:df:84:8b:0c STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:31.697: e8:39:df:84:8b:0c STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:31.697: e8:39:df:84:8b:0c Processing RSN IE type 48, length 20 for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Deleted mobile LWAPP rule on AP [00:1d:70:01:b5:a0]
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c Updated location for station old AP 00:1d:70:01:b5:a0-0, new AP 00:1d:70:01:b7:f0-0
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Change state to START (0) last state RUN (20)
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c 192.168.243.45 START (0) Initializing policy
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c 192.168.243.45 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c 192.168.243.45 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b7:f0 vapId 2 apVapId 2
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c apfPemAddUser2 (apf_policy.c:212) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from Associated to Associated
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c Stopping deletion of Mobile Station: (callerId: 48)
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c Sending Assoc Response to station on BSSID 00:1d:70:01:b7:f0 (status 0)
*Mar 04 10:45:31.698: e8:39:df:84:8b:0c apfProcessAssocReq (apf_80211.c:4361) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from Associated to Associated
*Mar 04 10:45:31.702: e8:39:df:84:8b:0c 192.168.243.45 Removed NPU entry.
*Mar 04 10:45:31.796: e8:39:df:84:8b:0c Creating a PKC PMKID Cache entry for station e8:39:df:84:8b:0c (RSN 2)
*Mar 04 10:45:31.796: e8:39:df:84:8b:0c Adding BSSID 00:1d:70:01:b7:f1 to PMKID cache for station e8:39:df:84:8b:0c
*Mar 04 10:45:31.796: New PMKID: (16)
*Mar 04 10:45:31.796:      [0000] 97 99 58 1b e9 58 dc 41 9c 73 36 bb 61 8d ac eb
*Mar 04 10:45:31.797: e8:39:df:84:8b:0c Initiating RSN PSK to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:31.797: e8:39:df:84:8b:0c dot1x - moving mobile e8:39:df:84:8b:0c into Force Auth state
*Mar 04 10:45:31.797: e8:39:df:84:8b:0c Skipping EAP-Success to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:31.797: Including PMKID in M1  (16)
*Mar 04 10:45:31.797:      [0000] 97 99 58 1b e9 58 dc 41 9c 73 36 bb 61 8d ac eb
*Mar 04 10:45:31.797: e8:39:df:84:8b:0c Starting key exchange to mobile e8:39:df:84:8b:0c, data packets will be dropped
*Mar 04 10:45:31.797: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.456: e8:39:df:84:8b:0c Association received from mobile on AP 00:1d:70:01:b7:f0
*Mar 04 10:45:33.456: e8:39:df:84:8b:0c Applying site-specific IPv6 override for station e8:39:df:84:8b:0c - vapId 2, site 'default-group', interface 'mpids_gh_if'
*Mar 04 10:45:33.456: e8:39:df:84:8b:0c Applying IPv6 Interface Policy for station e8:39:df:84:8b:0c - vlan 14, interface id 9, interface 'mpids_gh_if'
*Mar 04 10:45:33.456: e8:39:df:84:8b:0c STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:33.456: e8:39:df:84:8b:0c STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:33.456: e8:39:df:84:8b:0c Processing RSN IE type 48, length 20 for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.456: e8:39:df:84:8b:0c apfProcessAssocReq (apf_80211.c:4240) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from Associated to AAA Pending
*Mar 04 10:45:33.456: e8:39:df:84:8b:0c Scheduling deletion of Mobile Station:  (callerId: 20) in 10 seconds
*Mar 04 10:45:33.457: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Initializing policy
*Mar 04 10:45:33.457: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Change state to AUTHCHECK (2) last state RUN (20)
*Mar 04 10:45:33.457: e8:39:df:84:8b:0c 192.168.243.45 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Mar 04 10:45:33.457: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b7:f0 vapId 2 apVapId 2
*Mar 04 10:45:33.457: e8:39:df:84:8b:0c apfPemAddUser2 (apf_policy.c:212) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from AAA Pending to Associated
*Mar 04 10:45:33.457: e8:39:df:84:8b:0c Stopping deletion of Mobile Station: (callerId: 48)
*Mar 04 10:45:33.457: e8:39:df:84:8b:0c Sending Assoc Response to station on BSSID 00:1d:70:01:b7:f0 (status 0)
*Mar 04 10:45:33.457: e8:39:df:84:8b:0c apfProcessRadiusAssocResp (apf_80211.c:1956) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from Associated to Associated
*Mar 04 10:45:33.700: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:33.700: e8:39:df:84:8b:0c Retransmit 1 of EAPOL-Key M1 (length 121) for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.969: e8:39:df:84:8b:0c Association received from mobile on AP 00:1d:70:01:b5:a0
*Mar 04 10:45:33.969: e8:39:df:84:8b:0c Applying site-specific IPv6 override for station e8:39:df:84:8b:0c - vapId 2, site 'default-group', interface 'mpids_gh_if'
*Mar 04 10:45:33.969: e8:39:df:84:8b:0c Applying IPv6 Interface Policy for station e8:39:df:84:8b:0c - vlan 14, interface id 9, interface 'mpids_gh_if'
*Mar 04 10:45:33.969: e8:39:df:84:8b:0c STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:33.969: e8:39:df:84:8b:0c STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:33.969: e8:39:df:84:8b:0c Processing RSN IE type 48, length 20 for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.970: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Deleted mobile LWAPP rule on AP [00:1d:70:01:b7:f0]
*Mar 04 10:45:33.970: e8:39:df:84:8b:0c Updated location for station old AP 00:1d:70:01:b7:f0-0, new AP 00:1d:70:01:b5:a0-0
*Mar 04 10:45:33.970: e8:39:df:84:8b:0c apfProcessAssocReq (apf_80211.c:4240) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b5:a0 from Associated to AAA Pending
*Mar 04 10:45:33.970: e8:39:df:84:8b:0c Scheduling deletion of Mobile Station:  (callerId: 20) in 10 seconds
*Mar 04 10:45:33.971: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Initializing policy
*Mar 04 10:45:33.971: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Change state to AUTHCHECK (2) last state RUN (20)
*Mar 04 10:45:33.971: e8:39:df:84:8b:0c 192.168.243.45 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Mar 04 10:45:33.971: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b5:a0 vapId 2 apVapId 2
*Mar 04 10:45:33.971: e8:39:df:84:8b:0c apfPemAddUser2 (apf_policy.c:212) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b5:a0 from AAA Pending to Associated
*Mar 04 10:45:33.971: e8:39:df:84:8b:0c Stopping deletion of Mobile Station: (callerId: 48)
*Mar 04 10:45:33.971: e8:39:df:84:8b:0c Sending Assoc Response to station on BSSID 00:1d:70:01:b5:a0 (status 0)
*Mar 04 10:45:33.971: e8:39:df:84:8b:0c apfProcessRadiusAssocResp (apf_80211.c:1956) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b5:a0 from Associated to Associated
*Mar 04 10:45:33.977: e8:39:df:84:8b:0c Creating a PKC PMKID Cache entry for station e8:39:df:84:8b:0c (RSN 2)
*Mar 04 10:45:33.977: e8:39:df:84:8b:0c Adding BSSID 00:1d:70:01:b5:a1 to PMKID cache for station e8:39:df:84:8b:0c
*Mar 04 10:45:33.977: New PMKID: (16)
*Mar 04 10:45:33.977:      [0000] 1a 3a 8b 04 05 59 7f f2 71 cb 4c 32 9c c2 3e 4d
*Mar 04 10:45:33.977: e8:39:df:84:8b:0c Initiating RSN PSK to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.978: e8:39:df:84:8b:0c dot1x - moving mobile e8:39:df:84:8b:0c into Force Auth state
*Mar 04 10:45:33.978: e8:39:df:84:8b:0c Skipping EAP-Success to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.978: Including PMKID in M1  (16)
*Mar 04 10:45:33.978:      [0000] 1a 3a 8b 04 05 59 7f f2 71 cb 4c 32 9c c2 3e 4d
*Mar 04 10:45:33.978: e8:39:df:84:8b:0c Starting key exchange to mobile e8:39:df:84:8b:0c, data packets will be dropped
*Mar 04 10:45:33.978: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.983: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.984: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.984: e8:39:df:84:8b:0c Received EAPOL-key in PTK_START state (message 2) from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.984: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.984: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.990: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.990: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.990: e8:39:df:84:8b:0c Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.990: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Mar 04 10:45:33.991: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b5:a0 vapId 2 apVapId 2
*Mar 04 10:45:33.991: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Mar 04 10:45:33.992: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Reached PLUMBFASTPATH: from line 4574
*Mar 04 10:45:33.992: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Adding Fast Path rule
*Mar 04 10:45:33.992: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*Mar 04 10:45:33.992: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:33.996: e8:39:df:84:8b:0c 192.168.243.45 Added NPU entry of type 1, dtlFlags 0x0
*Mar 04 10:45:34.028: e8:39:df:84:8b:0c DHCP received op BOOTREQUEST (1) (len 324, port 1, encap 0xec03)
*Mar 04 10:45:34.029: e8:39:df:84:8b:0c DHCP selecting relay 1 - control block settings:
*Mar 04 10:45:34.029: e8:39:df:84:8b:0c DHCP selected relay 1 - 192.168.243.1 (local address 192.168.243.1, gateway 192.168.243.1, VLAN 14, port 1)
*Mar 04 10:45:34.030: e8:39:df:84:8b:0c DHCP transmitting DHCP REQUEST (3)
*Mar 04 10:45:34.030: e8:39:df:84:8b:0c DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*Mar 04 10:45:34.030: e8:39:df:84:8b:0c DHCP   xid: 0xfaa3e1da (4205044186), secs: 0, flags: 0
*Mar 04 10:45:34.030: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:45:34.031: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*Mar 04 10:45:34.031: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.243.1
*Mar 04 10:45:34.031: e8:39:df:84:8b:0c DHCP   requested ip: 192.168.243.45
*Mar 04 10:45:34.032: e8:39:df:84:8b:0c DHCP selecting relay 2 - control block settings:
*Mar 04 10:45:34.032: e8:39:df:84:8b:0c DHCP selected relay 2 - NONE
*Mar 04 10:45:34.032: e8:39:df:84:8b:0c DHCP received op BOOTREPLY (2) (len 548, port 0, encap 0x0)
*Mar 04 10:45:34.033: e8:39:df:84:8b:0c DHCP sending REPLY to STA (len 418, port 1, vlan 252)
*Mar 04 10:45:34.033: e8:39:df:84:8b:0c DHCP transmitting DHCP ACK (5)
*Mar 04 10:45:34.034: e8:39:df:84:8b:0c DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*Mar 04 10:45:34.034: e8:39:df:84:8b:0c DHCP   xid: 0xfaa3e1da (4205044186), secs: 0, flags: 0
*Mar 04 10:45:34.034: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:45:34.034: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 192.168.243.45
*Mar 04 10:45:34.035: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*Mar 04 10:45:34.035: e8:39:df:84:8b:0c DHCP   server id: 1.1.1.1  rcvd server id: 192.168.243.1
*Mar 04 10:45:36.305: e8:39:df:84:8b:0c Creating a PKC PMKID Cache entry for station e8:39:df:84:8b:0c (RSN 2)
*Mar 04 10:45:36.305: e8:39:df:84:8b:0c Adding BSSID 00:1d:70:01:b5:a1 to PMKID cache for station e8:39:df:84:8b:0c
*Mar 04 10:45:36.305: New PMKID: (16)
*Mar 04 10:45:36.305:      [0000] 1a 3a 8b 04 05 59 7f f2 71 cb 4c 32 9c c2 3e 4d
*Mar 04 10:45:36.305: e8:39:df:84:8b:0c Initiating RSN PSK to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:36.305: e8:39:df:84:8b:0c dot1x - moving mobile e8:39:df:84:8b:0c into Force Auth state
*Mar 04 10:45:36.306: e8:39:df:84:8b:0c Skipping EAP-Success to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:36.306: Including PMKID in M1  (16)
*Mar 04 10:45:36.306:      [0000] 1a 3a 8b 04 05 59 7f f2 71 cb 4c 32 9c c2 3e 4d
*Mar 04 10:45:36.306: e8:39:df:84:8b:0c Starting key exchange to mobile e8:39:df:84:8b:0c, data packets will be dropped
*Mar 04 10:45:36.306: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:38.300: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:38.300: e8:39:df:84:8b:0c Retransmit 1 of EAPOL-Key M1 (length 121) for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:40.300: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:40.300: e8:39:df:84:8b:0c Retransmit 2 of EAPOL-Key M1 (length 121) for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:41.568: e8:39:df:84:8b:0c Reassociation received from mobile on AP 00:1d:70:01:b7:f0
*Mar 04 10:45:41.568: e8:39:df:84:8b:0c Applying site-specific IPv6 override for station e8:39:df:84:8b:0c - vapId 2, site 'default-group', interface 'mpids_gh_if'
*Mar 04 10:45:41.568: e8:39:df:84:8b:0c Applying IPv6 Interface Policy for station e8:39:df:84:8b:0c - vlan 14, interface id 9, interface 'mpids_gh_if'
*Mar 04 10:45:41.568: e8:39:df:84:8b:0c STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:41.568: e8:39:df:84:8b:0c STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c Processing RSN IE type 48, length 20 for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Deleted mobile LWAPP rule on AP [00:1d:70:01:b5:a0]
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c Updated location for station old AP 00:1d:70:01:b5:a0-0, new AP 00:1d:70:01:b7:f0-0
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Change state to START (0) last state RUN (20)
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c 192.168.243.45 START (0) Initializing policy
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c 192.168.243.45 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c 192.168.243.45 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b7:f0 vapId 2 apVapId 2
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c apfPemAddUser2 (apf_policy.c:212) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from Associated to Associated
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c Stopping deletion of Mobile Station: (callerId: 48)
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c Sending Assoc Response to station on BSSID 00:1d:70:01:b7:f0 (status 0)
*Mar 04 10:45:41.569: e8:39:df:84:8b:0c apfProcessAssocReq (apf_80211.c:4361) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from Associated to Associated
*Mar 04 10:45:41.573: e8:39:df:84:8b:0c 192.168.243.45 Removed NPU entry.
*Mar 04 10:45:42.300: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:42.300: e8:39:df:84:8b:0c Retransmit 3 of EAPOL-Key M1 (length 121) for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.394: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.394: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.394: e8:39:df:84:8b:0c Received EAPOL-key in PTK_START state (message 2) from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.395: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.395: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
        state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.04
*Mar 04 10:45:42.407: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.407: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.407: e8:39:df:84:8b:0c Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.407: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Mar 04 10:45:42.407: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b7:f0 vapId 2 apVapId 2
*Mar 04 10:45:42.407: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Mar 04 10:45:42.408: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Reached PLUMBFASTPATH: from line 4574
*Mar 04 10:45:42.408: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Adding Fast Path rule
  on AP 00:1d:70:01:b7:f0, slot 0, interface = 1, QOS = 0
*Mar 04 10:45:42.409: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*Mar 04 10:45:42.409: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:42.412: e8:39:df:84:8b:0c 192.168.243.45 Added NPU entry of type 1, dtlFlags 0x0
*Mar 04 10:45:44.510: e8:39:df:84:8b:0c Creating a PKC PMKID Cache entry for station e8:39:df:84:8b:0c (RSN 2)
*Mar 04 10:45:44.510: e8:39:df:84:8b:0c Adding BSSID 00:1d:70:01:b7:f1 to PMKID cache for station e8:39:df:84:8b:0c
*Mar 04 10:45:44.510: New PMKID: (16)
*Mar 04 10:45:44.510:      [0000] 97 99 58 1b e9 58 dc 41 9c 73 36 bb 61 8d ac eb
*Mar 04 10:45:44.510: e8:39:df:84:8b:0c Initiating RSN PSK to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:44.510: e8:39:df:84:8b:0c dot1x - moving mobile e8:39:df:84:8b:0c into Force Auth state
*Mar 04 10:45:44.510: e8:39:df:84:8b:0c Skipping EAP-Success to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:44.511: Including PMKID in M1  (16)
*Mar 04 10:45:44.511:      [0000] 97 99 58 1b e9 58 dc 41 9c 73 36 bb 61 8d ac eb
*Mar 04 10:45:44.511: e8:39:df:84:8b:0c Starting key exchange to mobile e8:39:df:84:8b:0c, data packets will be dropped
*Mar 04 10:45:44.511: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:46.307: e8:39:df:84:8b:0c DHCP received op BOOTREQUEST (1) (len 324, port 1, encap 0xec03)
*Mar 04 10:45:46.307: e8:39:df:84:8b:0c DHCP selecting relay 1 - control block settings:
*Mar 04 10:45:46.307: e8:39:df:84:8b:0c DHCP selected relay 1 - 192.168.243.1 (local address 192.168.243.1, gateway 192.168.243.1, VLAN 14, port 1)
*Mar 04 10:45:46.307: e8:39:df:84:8b:0c DHCP transmitting DHCP REQUEST (3)
*Mar 04 10:45:46.307: e8:39:df:84:8b:0c DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*Mar 04 10:45:46.307: e8:39:df:84:8b:0c DHCP   xid: 0x27fda435 (670934069), secs: 1024, flags: 0
*Mar 04 10:45:46.307: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:45:46.308: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*Mar 04 10:45:46.308: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.243.1
*Mar 04 10:45:46.308: e8:39:df:84:8b:0c DHCP   requested ip: 192.168.243.45
*Mar 04 10:45:46.308: e8:39:df:84:8b:0c DHCP selecting relay 2 - control block settings:
*Mar 04 10:45:46.308: e8:39:df:84:8b:0c DHCP selected relay 2 - NONE
*Mar 04 10:45:46.309: e8:39:df:84:8b:0c DHCP received op BOOTREPLY (2) (len 548, port 0, encap 0x0)
*Mar 04 10:45:46.309: e8:39:df:84:8b:0c DHCP sending REPLY to STA (len 418, port 1, vlan 252)
*Mar 04 10:45:46.310: e8:39:df:84:8b:0c DHCP transmitting DHCP ACK (5)
*Mar 04 10:45:46.310: e8:39:df:84:8b:0c DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*Mar 04 10:45:46.310: e8:39:df:84:8b:0c DHCP   xid: 0x27fda435 (670934069), secs: 0, flags: 0
*Mar 04 10:45:46.310: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:45:46.310: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 192.168.243.45
*Mar 04 10:45:46.310: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*Mar 04 10:45:46.310: e8:39:df:84:8b:0c DHCP   server id: 1.1.1.1  rcvd server id: 192.168.243.1
*Mar 04 10:45:46.500: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:46.500: e8:39:df:84:8b:0c Retransmit 1 of EAPOL-Key M1 (length 121) for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:48.500: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:48.500: e8:39:df:84:8b:0c Retransmit 2 of EAPOL-Key M1 (length 121) for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:50.500: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:50.500: e8:39:df:84:8b:0c Retransmit 3 of EAPOL-Key M1 (length 121) for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:52.500: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:52.500: e8:39:df:84:8b:0c Retransmit 4 of EAPOL-Key M1 (length 121) for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.500: e8:39:df:84:8b:0c 802.1x 'timeoutEvt' Timer expired for station e8:39:df:84:8b:0c
*Mar 04 10:45:54.501: e8:39:df:84:8b:0c Retransmit failure for EAPOL-Key M1 to mobile e8:39:df:84:8b:0c, retransmit count 5, mscb deauth count 0
*Mar 04 10:45:54.502: e8:39:df:84:8b:0c Sent Deauthenticate to mobile on BSSID 00:1d:70:01:b7:f0 slot 0(caller 1x_ptsm.c:467)
*Mar 04 10:45:54.502: e8:39:df:84:8b:0c Scheduling deletion of Mobile Station:  (callerId: 57) in 10 seconds
*Mar 04 10:45:54.860: e8:39:df:84:8b:0c Association received from mobile on AP 00:1d:70:01:bc:20
*Mar 04 10:45:54.860: e8:39:df:84:8b:0c Applying site-specific IPv6 override for station e8:39:df:84:8b:0c - vapId 2, site 'default-group', interface 'mpids_gh_if'
*Mar 04 10:45:54.860: e8:39:df:84:8b:0c Applying IPv6 Interface Policy for station e8:39:df:84:8b:0c - vlan 14, interface id 9, interface 'mpids_gh_if'
*Mar 04 10:45:54.860: e8:39:df:84:8b:0c STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:54.860: e8:39:df:84:8b:0c STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:54.860: e8:39:df:84:8b:0c Processing RSN IE type 48, length 20 for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Deleted mobile LWAPP rule on AP [00:1d:70:01:b7:f0]
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c Updated location for station old AP 00:1d:70:01:b7:f0-0, new AP 00:1d:70:01:bc:20-0
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Change state to START (0) last state RUN (20)
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c 192.168.243.45 START (0) Initializing policy
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c 192.168.243.45 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c 192.168.243.45 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1d:70:01:bc:20 vapId 2 apVapId 2
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c apfPemAddUser2 (apf_policy.c:212) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:bc:20 from Associated to Associated
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c Stopping deletion of Mobile Station: (callerId: 48)
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c Sending Assoc Response to station on BSSID 00:1d:70:01:bc:20 (status 0)
*Mar 04 10:45:54.861: e8:39:df:84:8b:0c apfProcessAssocReq (apf_80211.c:4361) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:bc:20 from Associated to Associated
*Mar 04 10:45:54.865: e8:39:df:84:8b:0c 192.168.243.45 Removed NPU entry.
*Mar 04 10:45:54.876: e8:39:df:84:8b:0c Creating a PKC PMKID Cache entry for station e8:39:df:84:8b:0c (RSN 2)
*Mar 04 10:45:54.876: e8:39:df:84:8b:0c Adding BSSID 00:1d:70:01:bc:21 to PMKID cache for station e8:39:df:84:8b:0c
*Mar 04 10:45:54.876: New PMKID: (16)
*Mar 04 10:45:54.876:      [0000] c6 08 0c ca 6e 3a 2f 12 7f 1e dc b4 de 71 53 2c
*Mar 04 10:45:54.876: e8:39:df:84:8b:0c Initiating RSN PSK to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.876: e8:39:df:84:8b:0c dot1x - moving mobile e8:39:df:84:8b:0c into Force Auth state
*Mar 04 10:45:54.877: e8:39:df:84:8b:0c Skipping EAP-Success to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.877: Including PMKID in M1  (16)
*Mar 04 10:45:54.877:      [0000] c6 08 0c ca 6e 3a 2f 12 7f 1e dc b4 de 71 53 2c
*Mar 04 10:45:54.877: e8:39:df:84:8b:0c Starting key exchange to mobile e8:39:df:84:8b:0c, data packets will be dropped
*Mar 04 10:45:54.877: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.895: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.895: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.895: e8:39:df:84:8b:0c Received EAPOL-key in PTK_START state (message 2) from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.896: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:54.896: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c Reassociation received from mobile on AP 00:1d:70:01:b5:a0
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c Applying site-specific IPv6 override for station e8:39:df:84:8b:0c - vapId 2, site 'default-group', interface 'mpids_gh_if'
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c Applying IPv6 Interface Policy for station e8:39:df:84:8b:0c - vlan 14, interface id 9, interface 'mpids_gh_if'
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c Processing RSN IE type 48, length 20 for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Deleted mobile LWAPP rule on AP [00:1d:70:01:bc:20]
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c Updated location for station old AP 00:1d:70:01:bc:20-0, new AP 00:1d:70:01:b5:a0-0
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c apfProcessAssocReq (apf_80211.c:4240) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b5:a0 from Associated to AAA Pending
*Mar 04 10:45:55.247: e8:39:df:84:8b:0c Scheduling deletion of Mobile Station:  (callerId: 20) in 10 seconds
*Mar 04 10:45:55.248: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Initializing policy
*Mar 04 10:45:55.248: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Change state to AUTHCHECK (2) last state RUN (20)
*Mar 04 10:45:55.248: e8:39:df:84:8b:0c 192.168.243.45 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Mar 04 10:45:55.248: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b5:a0 vapId 2 apVapId 2
*Mar 04 10:45:55.248: e8:39:df:84:8b:0c apfPemAddUser2 (apf_policy.c:212) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b5:a0 from AAA Pending to Associated
*Mar 04 10:45:55.248: e8:39:df:84:8b:0c Stopping deletion of Mobile Station: (callerId: 48)
*Mar 04 10:45:55.248: e8:39:df:84:8b:0c Sending Assoc Response to station on BSSID 00:1d:70:01:b5:a0 (status 0)
*Mar 04 10:45:55.248: e8:39:df:84:8b:0c apfProcessRadiusAssocResp (apf_80211.c:1956) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b5:a0 from Associated to Associated
*Mar 04 10:45:55.255: e8:39:df:84:8b:0c Creating a PKC PMKID Cache entry for station e8:39:df:84:8b:0c (RSN 2)
*Mar 04 10:45:55.256: e8:39:df:84:8b:0c Adding BSSID 00:1d:70:01:b5:a1 to PMKID cache for station e8:39:df:84:8b:0c
*Mar 04 10:45:55.256: New PMKID: (16)
*Mar 04 10:45:55.256:      [0000] 1a 3a 8b 04 05 59 7f f2 71 cb 4c 32 9c c2 3e 4d
*Mar 04 10:45:55.256: e8:39:df:84:8b:0c Initiating RSN PSK to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.256: e8:39:df:84:8b:0c dot1x - moving mobile e8:39:df:84:8b:0c into Force Auth state
*Mar 04 10:45:55.256: e8:39:df:84:8b:0c Skipping EAP-Success to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.256: Including PMKID in M1  (16)
*Mar 04 10:45:55.256: e8:39:df:84:8b:0c Starting key exchange to mobile e8:39:df:84:8b:0c, data packets will be dropped
*Mar 04 10:45:55.257: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.262: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.262: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.262: e8:39:df:84:8b:0c Received EAPOL-key in PTK_START state (message 2) from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.262: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.263: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.273: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.273: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.273: e8:39:df:84:8b:0c Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.274: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Mar 04 10:45:55.274: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b5:a0 vapId 2 apVapId 2
*Mar 04 10:45:55.274: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Mar 04 10:45:55.275: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Reached PLUMBFASTPATH: from line 4574
*Mar 04 10:45:55.275: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Adding Fast Path rule
*Mar 04 10:45:55.275: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*Mar 04 10:45:55.275: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:55.279: e8:39:df:84:8b:0c 192.168.243.45 Added NPU entry of type 1, dtlFlags 0x0
*Mar 04 10:45:55.307: e8:39:df:84:8b:0c DHCP received op BOOTREQUEST (1) (len 324, port 1, encap 0xec03)
*Mar 04 10:45:55.307: e8:39:df:84:8b:0c DHCP selecting relay 1 - control block settings:
*Mar 04 10:45:55.307: e8:39:df:84:8b:0c DHCP selected relay 1 - 192.168.243.1 (local address 192.168.243.1, gateway 192.168.243.1, VLAN 14, port 1)
*Mar 04 10:45:55.308: e8:39:df:84:8b:0c DHCP transmitting DHCP REQUEST (3)
*Mar 04 10:45:55.308: e8:39:df:84:8b:0c DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*Mar 04 10:45:55.308: e8:39:df:84:8b:0c DHCP   xid: 0x8c84a505 (2357503237), secs: 0, flags: 0
*Mar 04 10:45:55.309: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:45:55.309: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*Mar 04 10:45:55.309: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.243.1
*Mar 04 10:45:55.309: e8:39:df:84:8b:0c DHCP   requested ip: 192.168.243.45
*Mar 04 10:45:55.310: e8:39:df:84:8b:0c DHCP selecting relay 2 - control block settings:
*Mar 04 10:45:55.310: e8:39:df:84:8b:0c DHCP selected relay 2 - NONE
*Mar 04 10:45:55.310: e8:39:df:84:8b:0c DHCP received op BOOTREPLY (2) (len 548, port 0, encap 0x0)
*Mar 04 10:45:55.311: e8:39:df:84:8b:0c DHCP sending REPLY to STA (len 418, port 1, vlan 252)
*Mar 04 10:45:55.311: e8:39:df:84:8b:0c DHCP transmitting DHCP ACK (5)
*Mar 04 10:45:55.311: e8:39:df:84:8b:0c DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*Mar 04 10:45:55.312: e8:39:df:84:8b:0c DHCP   xid: 0x8c84a505 (2357503237), secs: 0, flags: 0
*Mar 04 10:45:55.312: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:45:55.312: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 192.168.243.45
*Mar 04 10:45:55.312: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*Mar 04 10:45:55.313: e8:39:df:84:8b:0c DHCP   server id: 1.1.1.1  rcvd server id: 192.168.243.1
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c Reassociation received from mobile on AP 00:1d:70:01:b7:f0
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c Applying site-specific IPv6 override for station e8:39:df:84:8b:0c - vapId 2, site 'default-group', interface 'mpids_gh_if'
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c Applying IPv6 Interface Policy for station e8:39:df:84:8b:0c - vlan 14, interface id 9, interface 'mpids_gh_if'
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c STA - rates (8): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c STA - rates (12): 130 132 139 150 12 18 24 36 48 72 96 108 0 0 0 0
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c Processing RSN IE type 48, length 20 for mobile e8:39:df:84:8b:0c
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Deleted mobile LWAPP rule on AP [00:1d:70:01:b5:a0]
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c Updated location for station old AP 00:1d:70:01:b5:a0-0, new AP 00:1d:70:01:b7:f0-0
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Change state to START (0) last state RUN (20)
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c 192.168.243.45 START (0) Initializing policy
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c 192.168.243.45 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c 192.168.243.45 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b7:f0 vapId 2 apVapId 2
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c apfPemAddUser2 (apf_policy.c:212) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from Associated to Associated
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c Stopping deletion of Mobile Station: (callerId: 48)
*Mar 04 10:45:59.366: e8:39:df:84:8b:0c Sending Assoc Response to station on BSSID 00:1d:70:01:b7:f0 (status 0)
*Mar 04 10:45:59.367: e8:39:df:84:8b:0c apfProcessAssocReq (apf_80211.c:4361) Changing state for mobile e8:39:df:84:8b:0c on AP 00:1d:70:01:b7:f0 from Associated to Associated
*Mar 04 10:45:59.370: e8:39:df:84:8b:0c 192.168.243.45 Removed NPU entry.
*Mar 04 10:46:02.312: e8:39:df:84:8b:0c Creating a PKC PMKID Cache entry for station e8:39:df:84:8b:0c (RSN 2)
*Mar 04 10:46:02.313: e8:39:df:84:8b:0c Adding BSSID 00:1d:70:01:b7:f1 to PMKID cache for station e8:39:df:84:8b:0c
*Mar 04 10:46:02.313: New PMKID: (16)
*Mar 04 10:46:02.313:      [0000] 97 99 58 1b e9 58 dc 41 9c 73 36 bb 61 8d ac eb
*Mar 04 10:46:02.313: e8:39:df:84:8b:0c Initiating RSN PSK to mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.313: e8:39:df:84:8b:0c dot1x - moving mobile e8:39:df:84:8b:0c into Force Auth state
*Mar 04 10:46:02.313: e8:39:df:84:8b:0c Skipping EAP-Success to mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.313: Including PMKID in M1  (16)
*Mar 04 10:46:02.313: e8:39:df:84:8b:0c Starting key exchange to mobile e8:39:df:84:8b:0c, data packets will be dropped
*Mar 04 10:46:02.314: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.439: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.439: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.440: e8:39:df:84:8b:0c Received EAPOL-key in PTK_START state (message 2) from mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.440: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.440: e8:39:df:84:8b:0c Sending EAPOL-Key Message to mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.496: e8:39:df:84:8b:0c Received EAPOL-Key from mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.497: e8:39:df:84:8b:0c Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.497: e8:39:df:84:8b:0c Received EAPOL-key in PTKINITNEGOTIATING state (message 4) from mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.497: e8:39:df:84:8b:0c 192.168.243.45 8021X_REQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Mar 04 10:46:02.497: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 00:1d:70:01:b7:f0 vapId 2 apVapId 2
*Mar 04 10:46:02.497: e8:39:df:84:8b:0c 192.168.243.45 L2AUTHCOMPLETE (4) Change state to RUN (20) last state RUN (20)
*Mar 04 10:46:02.498: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Reached PLUMBFASTPATH: from line 4574
*Mar 04 10:46:02.498: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Adding Fast Path rule
*Mar 04 10:46:02.499: e8:39:df:84:8b:0c 192.168.243.45 RUN (20) Successfully plumbed mobile rule (ACL ID 255)
*Mar 04 10:46:02.499: e8:39:df:84:8b:0c Stopping retransmission timer for mobile e8:39:df:84:8b:0c
*Mar 04 10:46:02.502: e8:39:df:84:8b:0c 192.168.243.45 Added NPU entry of type 1, dtlFlags 0x0
*Mar 04 10:46:06.483: e8:39:df:84:8b:0c DHCP received op BOOTREQUEST (1) (len 324, port 1, encap 0xec03)
*Mar 04 10:46:06.483: e8:39:df:84:8b:0c DHCP selecting relay 1 - control block settings:
*Mar 04 10:46:06.483: e8:39:df:84:8b:0c DHCP selected relay 1 - 192.168.243.1 (local address 192.168.243.1, gateway 192.168.243.1, VLAN 14, port 1)
*Mar 04 10:46:06.483: e8:39:df:84:8b:0c DHCP transmitting DHCP REQUEST (3)
*Mar 04 10:46:06.483: e8:39:df:84:8b:0c DHCP   op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
*Mar 04 10:46:06.483: e8:39:df:84:8b:0c DHCP   xid: 0x24de6853 (618555475), secs: 1024, flags: 0
*Mar 04 10:46:06.483: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:46:06.484: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 0.0.0.0
*Mar 04 10:46:06.484: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 192.168.243.1
*Mar 04 10:46:06.484: e8:39:df:84:8b:0c DHCP   requested ip: 192.168.243.45
*Mar 04 10:46:06.484: e8:39:df:84:8b:0c DHCP selecting relay 2 - control block settings:
*Mar 04 10:46:06.484: e8:39:df:84:8b:0c DHCP selected relay 2 - NONE
*Mar 04 10:46:06.485: e8:39:df:84:8b:0c DHCP received op BOOTREPLY (2) (len 548, port 0, encap 0x0)
*Mar 04 10:46:06.485: e8:39:df:84:8b:0c DHCP sending REPLY to STA (len 418, port 1, vlan 252)
*Mar 04 10:46:06.485: e8:39:df:84:8b:0c DHCP transmitting DHCP ACK (5)
*Mar 04 10:46:06.486: e8:39:df:84:8b:0c DHCP   op: BOOTREPLY, htype: Ethernet, hlen: 6, hops: 0
*Mar 04 10:46:06.486: e8:39:df:84:8b:0c DHCP   xid: 0x24de6853 (618555475), secs: 0, flags: 0
*Mar 04 10:46:06.486: e8:39:df:84:8b:0c DHCP   chaddr: e8:39:df:84:8b:0c
*Mar 04 10:46:06.486: e8:39:df:84:8b:0c DHCP   ciaddr: 0.0.0.0,  yiaddr: 192.168.243.45
*Mar 04 10:46:06.486: e8:39:df:84:8b:0c DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
