problems with session duration for 1 client
lydia.walther
Level 3
Level 3
we have some problems with one of our wifi clients.
The wireless lan controller is a model 4402 with software version 6.0.196.0.
The access points are connected via mesh mode! The status seems to be stable (Uptime of two access points
in the third floor is about 10 days).
Normally we only provide one wireless network with WPA+WPA2 and WEB-Auth. But since two weeks there is a guest
who says he's beeing disconnected very often. Because we thought it would be a problem with the WEB-Authentication and his apple computer,
we set up a new wifi network with mac address filter. But the guest is still complaining about the connection.
In the wireless control system reports I can see, that there are often connections of this guest which has a session duration
of exactly "5 min 0 sec". But in the meantime there are also session durations of several hours.
(Session timeout is not enabled! User Idle Timeout is set to 3000 seconds and ARP timeout is 300 seconds)
In the old version of WCS there was given a "reason code" for the disassociation of clients, but in this version I can't
see something like that. (I upgraded the version this week.)
In the trap log of the controller there are only messages like "Client Association" and "Client Authenticated" for the concerned client, but no entrys
for disassociation or deauthentication.
Other guests do not have this problem. It's only one guest using two different computers (1 Apple, 1 Windows).
Affected is the guest who's living in the highest floor of the house. Other guests in the first floor do not have
problems. Could this really be a problem of the mesh mode? We never had a guest before with so big problems.
Where can I found the reason for the clients new authentication? What is happening after exactly 5 minutes?
Does anybody has an idea?
During we tested the wifi with our computers there were no problems although we were sitting in the highest floor. We will do an endurance test for some hours tomorrow.
Greetings Lydia
21 Replies 21
Scott Fella
Well are these devices going to sleep? If so, then the idle timer would count down and then remove the client. You currently have it set for 3000 seconds or 50 minutes. Also is the device maybe trying to connect to another SSID? Maybe test again and remove any other SSID's that might affect the testing. Can you post the show WLAN again?
Do you see this issue when the client is in the 2.4ghz or 5ghz?
-Scott
the clients are using the 2,4ghz.
Here is the output of show wlan id:
(Cisco Controller) >show wlan 2
WLAN Identifier.................................. 2
Profile Name..................................... mpids_gh
Network Name (SSID).............................. mpids_gh
Status........................................... Enabled
MAC Filtering.................................... Enabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  NAC-State...................................... Disabled
  Quarantine VLAN................................ 0
Number of Active Clients......................... 2
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. Infinity
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ mpids_gh_if
WLAN ACL......................................... unconfigured
DHCP Server...................................... 192.168.243.1
DHCP Address Assignment Required................. Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Disabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
   CKIP ......................................... Disabled
   IP Security................................... Disabled
   IP Security Passthru.......................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Learn IP Address....................... Enabled
   Infrastructure MFP protection................. Disabled
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
For the client e8:39:df:84:8b:0c of which is the log I can't say if it is going to sleep (We don't have access to the device.). I would say no, because the user is complaining about the interrupts permanently. And always if there is a disassociation directly there is a new association.
For the macbook which belongs to us I can say, that it is not going to sleep (sleep mode is deactivated). We run a ping all the time (since friday morning).
A little while ago I saw all the clients of this wifi disassociating. Debugging one of the clients at this moment shows:
(Cisco Controller) >*Mar 04 13:27:27.002: 00:1e:52:7d:e8:e7 Cleaning up state for STA 00:1e:52:7d:e8:e7 due to event for AP 00:1d:70:01:b7:f0(0)
*Mar 04 13:27:27.005: 00:1e:52:7d:e8:e7 apfSendDisAssocMsgDebug (apf_80211.c:1682) Changing state for mobile 00:1e:52:7d:e8:e7 on AP 00:1d:70:01:b7:f0 from Associated to Disassociated
And under the "Most recent traps" there was written:
27    Mon Mar 4 13:27:27 2013    AP Disassociated. Base Radio MAC:00:1d:70:01:b7:f0
28    Mon Mar 4 13:27:27 2013    AP's Interface:1(802.11a) Operation State Down: Base Radio MAC:00:1d:70:01:b7:f0 Cause=Heartbeat Timeout
29    Mon Mar 4 13:27:27 2013    AP's Interface:0(802.11b) Operation State Down: Base Radio MAC:00:1d:70:01:b7:f0 Cause=Heartbeat Timeout
But I don't know how often this is occuring.
Meanwhile I found the column for "reason" in the client session reports. Nearly always there is written "new association detected" as reason for disassociation.
There are some other SSIDs within reach (some of us and some foreign) but I can't remove them. Sometimes I can see that the user is changing the wireless (always hoping to find a better connection), but this seems to take place uncomplicated.
Scott Fella
Have you eliminated any issues maybe with cabling? Do you see any errors on the switchport that the AP is connected to?
-Scott
It's a mesh network because there is only one network socket in the basement of the house.
That's why we installed an additional access point in the second floor on friday (user and test computer on third floor). We wanted to see if it stabilize the connection, but I'm not sure if this was helpful.
I suppose that if a computer placed in the third floor is connecting to the wireless network via the access point in the first floor, the session duration is very short - often exactly 5 minutes. I can see longer session durations if the connection is built up via the access point in the third floor. But sometimes the 5-minute-problem is occuring there too.
I don't know why a computer isn't using the access point next to it but rather this one two floors further down.
Root AP is in the basement, ground floor has 2 access points, first floor has 1 AP, second floor 2 AP and third floor 1 AP.
So you have a RAP in the basement and all the others are MAP's?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Yes, that's right.
So typically I don't like to go past two hops, so you need to see if your MAP is changing its parent or not which can cause issues for you.
Scott
-Scott
