08-18-2015 01:01 PM - edited 07-05-2021 03:47 AM
Dears,
Does anyone can confirm if bandwidth limitations configuration at WLC 5508 (jpeg attached) should work in remote sites APs (configured as flexconnect)?
We configured that parameter but it seems to be working only with our local APs (same office where WLC is located)... for remote APs ( config'd as remote/flexconnect) we cant see...
Solved! Go to Solution.
08-21-2015 09:53 AM
It Will not work.
Flexconnect has limitations .
The QoS profile per-user bandwidth contracts and bandwidth limitations configuration are not supported for FlexConnect locally switched WLANs.
There are many other limitations ,you can check on the link below.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-2/configuration/guide/cg/cg_flexconnect.html
08-21-2015 09:53 AM
It Will not work.
10-19-2015 06:48 AM
As of 7.3, bi-directional bandwidth limiting is supported in Flex. However, not all models of AP's support it.
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/113682-bdr-limit-guide-00.html
