QoS for wireless in SDA Fabric
aleopoldie
Level 3
Level 3
Hello all,
I would like to implement QoS on Wireless on my SDA Fabric, 5520 WLC's are used.
I created an application policy on the DNA Center for Wireless and deployed it on my test SSID. It created a FlexConnect AVC Profile, but here's the thing, my test SSID is not a local switching as SSID's created on the DNA Center are not pushed as local switching on the WLC, so Flexconnect AVC Profile can't be set. A standard AVC Profile would be needed in that case.
I attach some screenshots so you can have a better understanding.
Did someone face the same behaviour ?
Thank you,
Scott Fella
 I didn't think local switching was supported, only in non-fabric.  You might want to reach out to your Cisco SE for additional guidance.
-Scott
