Query on Autonomous AP Wireless bridge
BhaskarDS
I have a query on Autonomous AP Wireless bridge. Can we have point to multipoint setup ? i.e., one root bridge and multiple non-root bridge associating to that root bridge ?
4 Accepted Solutions
balaji.bandi
The guides are pretty old but autonomous is autonomous.  Just search for Cisco Autonomous Bridge multiple vlans and you should find a bunch of examples.
https://supportforums.cisco.com/document/61936/autonomous-ap-and-bridge-basic-configuration-template
http://mrncciew.com/2013/01/13/autonoumous-ap-wireless-bridges/
BB
Short answer is yes you can do point to point to multi-point with autonomous bridges.
Documentation on Autonomous mode APs is becoming very hard to find.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/atnms-ap-82/configuration/guide/cg-82-book/cg-chap1-overview.html
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1530/installation/guide/1530hig/1530_ch1.html#pgfId-1071535
Just keep in mind this when planning it:
The throughput is reduced depending on the number of non-root bridges that associate with the root bridge. With a link data rate at 54 Mbps, the maximum throughput is about 25 Mbps in a point-to-point link. The addition of three bridges to form a point-to-multipoint network reduces the throughput to about 12.5 Mbps
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Sandeep Choudhary
balaji.bandi
BB
Sandeep Choudhary
Yes you can do it.
https://rscciew.wordpress.com/2014/10/26/autonomous-ap-as-wireless-bridge-with-multiple-vlan/
Dont forget to rate helpful posts
Sandeep Choudhary
Yes you can do it.
