Quesion
wael azzam
Level 2
Level 2
Hi ,all
Is WAP121 can act as a repeater?
5 Replies 5
Scott Fella
Per this guide, the answer is yes. The ap would be in bridge mode. You would have to test this out. Doesn't say if it can be a repeater for another vendor ap or not if that is what your trying to accomplish.
See page 92
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
-Scott
Thanks Scott ,for your help and I will try it
Scott Fella
Let us know.
-Scott
Abhishek Abhishek
The WAP device can act as a single point-to-point mode access point, point-to-multipoint bridge, and as a repeater. In the point-to-point mode, a single WAP device accepts connections from clients and other devices in the network. In a point-to-multipoint bridge mode, a single WAP device behaves as a common link between many access points. WAP device can also act as a repeater, where it can establish a connection between access points which are far apart from each other. Wireless clients can connect to this repeater. A WDS role system can be compared similar to the role of the repeater.
For the configuration guide please refer to the following link-
http://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=ebf3c8a8d17f4e2f981393191638b799_Wireless_Distribution_System__WDS__Configuration_on_the_WAP1.xml&pid=2&converted=0
wael azzam
Level 2
Level 2
Thanks all ,
It is working ,just Abhishek said ,I configure the two access points in  WDS system using Mac Addresses and it worked
