wireless network
bobbymd19
Community Member
hello community i have a question bout extending range of my wireless network with my e900 smart wireless linksys router i have my wrt54g router i formerly used i want to use to extend coverage does anyone know how to do this thanks
Sent from Cisco Technical Support Android App
kaaftab
Level 9
Level 9
You can deploy wireless in the mesh mode and follow the following link for guidance
              http://www.htmlgraphic.com/creating-a-mesh-network-with-linksys-wireless-routers/
Ravi Singh
Level 11
Level 11
I would suggest you to conduct site survey first. Moreover Most wireless routers and  wireless adapters that have external antennas come with cheap  omnidirectional antennas (those that send the signals equally in all  directions). Replacing those cheap omnidirectional models with  higher-gain antennas (those that concentrate the signals in a specific  direction) can help increase your Wi-Fi range, especially if you have a  home or office that's narrow and extends predominantly in one direction  from the router's location. If that's the case, consider purchasing any  higher-gain antennas that the vendor recommends for your particular  router and/or wireless adapters
