09-10-2020 09:01 AM - edited 07-05-2021 12:30 PM
I've a question about AP switch port speed.
When you have a remote WLC and APs connected on a 100mbps switch ports on site.
If one Wifi client is connected on 5ghz with 80Mhz channel width and see +700 mbps in Data Rate details of his Wireless adapter, will it still be limited by the 100mbps switch port ?
Solved! Go to Solution.
09-10-2020 10:50 AM
Not sure what is the Mode of the AP ?
+700 mbps transfer rates ? - you will not get since AP connected to 100Mb port -your views are correct. you can not get more than 100MB.
that rate are between client and AP over wireless - not wire speed.
09-10-2020 10:50 AM
09-10-2020 04:07 PM
Yes. The bottleneck will be the 100 Mbps port.
