Question about configuring Cisco 9120AXE-F via serial console
Naufal Arkaan
Hi there,
I am new on cisco and I have cisco 9120AXE-F and it's new. To power on the product, I connect to POE+ injector AIR-PWRINJ6 and for configure I have console cable to usb with my laptop and it is running well and i can see boot process for the it. Then I dont know why it is stuck on this with 2 hours i am waiting :
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
U-Boot 2017.09 (Jun 01 2022 - 09:52:21 -0700) Broadcom BCM49408
Board: VANC-e
I2C: ready
DRAM: 2 GiB
enable MMU ... OK
NAND: Status wait timeout: nandsts=0x0 mask=0x40000000, count=0
NAND ECC BCH-8, page size 4096 bytes, spare size used 216 bytes
1024 MiB
MMC:
SF: Detected mx25l6405d with page size 256 Bytes, erase size 4 KiB, total 8 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Platform: 4908
pmc_init:PMC using DQM mode
pmc_patch_4908:7 0 fefb043f 3420341
Board IP address : 192.168.1.1:ffffff00
Host IP address : 192.168.1.200
Gateway IP address : 10.1.1.1
Run from flash/host/tftp (f/h/c) : f
Default host run file name : vmlinux
Default host flash file name : bcm963xx_fs_kernel
Boot delay (0-9 seconds) : 3
Default host ramdisk file name :
Default ramdisk store address :
Board Id (0-18) : VANC_54991
Number of MAC Addresses (1-32) : 11
Base MAC Address : 58:8b:1c:b6:3c:90
PSI Size (1-128) KBytes : 48
Enable Backup PSI [0|1] : 0
System Log Size (0-256) KBytes : 0
Auxillary File System Size Percent: 0
flow memory allocation (MB) : 43
buffer memory allocation (MB) : 16
DHD 0 memory allocation (MB) : 0
DHD 1 memory allocation (MB) : 0
DHD 2 memory allocation (MB) : 0
Partition 1 Size (MB) : 0M
Partition 2 Size (MB) : 0M
Partition 3 Size (MB) : 0M
Partition 4 Size (MB) (Data) : 4M
BootImage: MASTER
Sign verify failed (err=-2)
Found external PHY firmware image
MTDPART Str = (mtdparts=nand:1m(nvram),5888k(bootfs),-(fs))
Net: Registering Ethernet Driver.....
Broadcom BCM 4908 Ethernet driver 0.1
pmc_switch_power_up: Rgmii Tx clock zone1 enable 0 zone2 enable 0.
Setting SGMII Calibration value to 0x8
swap_pair = 0
Detecting PHYs...
84880 A0 ae02:5158 --> N/A
84881 A0 ae02:5150 --> N/A
84884 A0 ae02:5148 --> N/A
84884E A0 ae02:5168 --> N/A
84885 A0 ae02:5178 --> N/A
84886 A0 ae02:5170 --> N/A
84887 A0 ae02:5144 --> N/A
84888 A0 ae02:5140 --> N/A
84888E A0 ae02:5160 --> N/A
84888S A0 ae02:5174 --> N/A
84880 B0 ae02:5159 --> N/A
84881 B0 ae02:5151 --> N/A
84884 B0 ae02:5149 --> N/A
84884E B0 ae02:5169 --> N/A
84885 B0 ae02:5179 --> N/A
84886 B0 ae02:5171 --> N/A
84887 B0 ae02:5145 --> N/A
84888 B0 ae02:5141 --> N/A
84888E B0 ae02:5161 --> N/A
84888S B0 ae02:5175 --> N/A
84891 A0 3590:5090 --> N/A
54991 A0 3590:5094 --> N/A
54991E A0 3590:5098 --> N/A
84891L A0 3590:5080 --> N/A
54991L A0 3590:5084 --> N/A
54991EL A0 3590:5088 --> N/A
84892 A0 3590:50a0 --> N/A
54992 A0 3590:50a4 --> N/A
54992E A0 3590:50a8 --> N/A
84894 A0 3590:50b0 --> N/A
54994 A0 3590:50b4 --> N/A
54994E A0 3590:50b8 --> N/A
54991H A0 3590:50d0 --> N/A
54994H A0 3590:50f0 --> N/A
84891 B0 3590:5091 --> N/A
54991 B0 3590:5095 --> N/A
54991E B0 3590:5099 --> N/A
84891L B0 3590:5081 --> N/A
54991L B0 3590:5085 --> N/A
54991EL B0 3590:5089 --> 0x1f
84892 B0 3590:50a1 --> N/A
54992 B0 3590:50a5 --> N/A
54992E B0 3590:50a9 --> N/A
84894 B0 3590:50b1 --> N/A
54994 B0 3590:50b5 --> N/A
54994E B0 3590:50b9 --> N/A
54991H B0 3590:50d1 --> N/A
54994H B0 3590:50f1 --> N/A
Loading firmware into detected phys...
bcm4908_eth-0
MAC: 58:8b:1c:b6:3c:90
Hit ESC key to stop autoboot: 0
Mounting UBI device fs
ubi0: attaching mtd3
ubi0: scanning is finished
ubi0: attached mtd3 (name "mtd=2", size 1017 MiB)
ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 253952 bytes
ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 4096
ubi0: VID header offset: 4096 (aligned 4096), data offset: 8192
ubi0: good PEBs: 4065, bad PEBs: 4, corrupted PEBs: 0
ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 38517316
ubi0: available PEBs: 33, total reserved PEBs: 4032, PEBs reserved for bad PEB handling: 76
Load Addr 0x10000000
Mount UBIFS PARTITION part1 ...
Loading file 'part1/part.bin' to addr 0x10000000...
Done
Checking image signing.
Image signing verification success for part part1 continue to run...
Multi Image Header Found
Count = 0 Offset = 0x10000050 Len = 11199200
Count = 1 Offset = 0x10aae330 Len = 3624983
Count = 2 Offset = 0x10e23348 Len = 7202
Booting from Partition: part1
arg 0: 0x10000050
arg 1: 0x3000000
arg 2: 0x1800000
## Loading init Ramdisk from Legacy Image at 03000000 ...
Image Name: Simple Ramdisk Image
Created: 2022-08-11 0:34:38 UTC
Image Type: AArch64 Linux RAMDisk Image (lzma compressed)
Data Size: 3624919 Bytes = 3.5 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 01800000
Booting using the fdt blob at 0x1800000
load dtb from fixed memory location directly...
/memory = 0x80000000 bytes @ 0x0
Set Memory to 2147483648l
WARNING: Node's property /reserved-memory/dt_reserved_buffer is not defined
WARNING: Node's property /reserved-memory/dt_reserved_flow is not defined
Appending NVRAM to dtb, ret:0
Loaded DTB from 0x01800000 with size 7202l
Curr Boot Args: <NULL>
DTB Boot Args (coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M)
Bootargs set to setenv bootargs console=$consoledev,$baudrate activepart=part1 activeboot=0 bootver=0x50 boardid=0x3 forceboot=0 coherent_pool=4M cpuidle_sysfs_switch pci=pcie_bus_safe rootwait crashkernel=128M@0M $console $nandEcc $mtdparts ubi.mtd=fs BOOT_DEBUG=0
Cleanup Complete.... ARMv8_secure_init_done!!!
Loading Ramdisk to 4fb31000, end 4fea5fd7 ... OK
reserving fdt memory region: addr=0 size=20000
Using Device Tree in place at 0000000001800000, end 0000000001804c21
Starting kernel ...
[01/01/1970 00:00:05.1680] hub 3-0:1.0: config failed, hub doesn't have any ports! (err -19)
[01/01/1970 00:00:05.2600] brcmboard registered
[*01/01/1970 00:00:16.8830] buginf() enabled.
[*01/01/1970 00:00:16.8900] Made it into bootsh: Aug 11 2022 00:10:33 T-24d9397ced0a4659b2d7c81901185234c3a17e4e-g24d9397c-aut
[*01/01/1970 00:00:25.6580] bootsh mini ramfs booted /bootpart/part1/ramfs_data_cisco.cpio.lzma
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[*01/01/1970 00:00:51.5620] init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:51.5650] init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:51.5670] init: ioctl(SIOCGIFHWADDR): wired0: No such device
[*01/01/1970 00:00:51.5700] init: ioctl(SIOCGIFHWADDR): wired0: No such device
Press S for a shell, or another magic key...
[ OK ] Created slice -.slice.
[ OK ] Created slice system.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Reached target Slices.
J▒▒▒&j OK ] Reached target Sockets.n Socket.
[ OK ] Reached target Timers.
[ OK ] Reached target Cisco File Systems (Pre).
Starting Cisco UBIFS reformat/mount...
[*01/01/1970 00:00:56.2360] root: Cisco Axel file system mounting
[ OK ] Created slice system-sshd\x2dkeygen.slice.
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco system time setup...
[*07/06/2023 23:59:59.0090] Last reload time: Jan 22 09:58:36 2025
[*01/22/2025 09:58:36.0000] Setting system time Wed Jan 22 09:58:36 UTC 2025
Starting Cisco platform file generation...
Starting Cisco fips check...
Starting Cisco seed generation...
[*01/22/2025 09:58:36.3190] GCM-128 POST passed
[*01/22/2025 09:58:36.3190] GCM-256 POST passed
[*01/22/[ OK ] Started Cisco system time setup.
▒▒5▒j OK ] Started Cisco fips check.eneration.
[ OK ] Started Cisco seed generation.
Starting Cisco btldr service...
[*01/22/2025 09:58:36.6710]
[*01/22/2025 09:58:36.6710] [1/22/2025 9:59:37] : Shadow is now in-synced with master
[ OK ] Started Cisco btldr service.
[ OK ] Reached target Local File Systems.
*Starting Cisco system time saving...ving.
Starting Cisco pkg install service...
Starting Cisco act2 check...
Starting Cisco S10 boot service...
[01/22/2025 09:58:37.4630] bcmlibs: module license 'Proprietary' taints kernel.
[01/22/2025 09:58:37.5410] Disabling lock debugging due to kernel taint
[01/22/2025 09:58:37.9380] bm_base_addr 0xffffffc006000000, size 67108864, bm_base_addr_phys 0x0000000006000000
[01/22/2025 09:58:38.0490] fm_base_addr 0xffffffc002e00000, size 12582912, fm_base_addr_phys 0x0000000002e00000
[01/22/2025 09:58:38.8740] Broadcom Command List Driver v1.0
[01/22/2025 09:58:38.9550] crossbar[0]: Allocated cb_idx=0 int_ep=0
[01/22/2025 09:58:39.0200] crossbar[0]: Add cb_idx=0 ext_ep=0 SERDES:6
[01/22/2025 09:58:39.0950]
[01/22/2025 09:58:39.0950] Detecting PHYs...
[01/22/2025 09:58:39.1730] Lift PHY at address 31 out of Reset by GPIO:31 Active Low
[01/22/2025 09:58:39.2700] 54991EL B0 3590:5089 --> 0x1f
[01/22/2025 09:58:39.3270]
[01/22/2025 09:58:39.3270] Loading firmware into detected PHYs...
[01/22/2025 09:58:39.4570] Firmware version: Blackfin B0 v02-02-03-2020-03-16
[01/22/2025 09:58:39.5390] Loading firmware into PHYs: map=0x80000000 count=1
[01/22/2025 09:58:39.6220] Halt the PHYs processors operation
[01/22/2025 09:58:39.6900] Upload the firmware into the on-chip memory
79%/22/2025 09:58:39.7630]
[01/22/2025 09:58:42.3810] audit_printk_skb: 102 callbacks suppressed
84%[01/22/2025 09:58:42.4500]
88%stall service.Cisco pkg in
100%
[01/22/2025 09:58:43.1060] Reset the processors to start execution of the code in the on-chip memory
[01/22/2025 09:58:43.2120] Verify that the processors are running: OK
[01/22/2025 09:58:43.7610] Verify that the firmware has been loaded with good CRC: OK
[01/22/2025 09:58:43.8480] Firmware loading completed successfully
[01/22/2025 09:58:43.9500] Adjusted SF2 SGPHY: sphy_ctrl=0x00010c1b
[01/22/2025 09:58:44.0350] getrcal for res select 5, int 663, ext 651, ratio 125 ratio1 140, rcal 8
[01/22/2025 09:58:44.1330] Setting SGMII Calibration value to 0x8
[01/22/2025 09:58:44.2030] PLL_PON(8051): 0x0210; TX_PON(8067): 0x0040; RX_PON(80b2): 0x0880
[01/22/2025 09:58:44.8310] dgasp: kerSysRegisterDyingGaspHandler: bcmsw registered
[ OK ] Started Cisco S10 boot service.
Starting Cisco watchdog...
Starting Cisco marlin_sia module service...
Starting Cisco nolan service...
Starting Cisco nss service...
[ OK ] Started Cisco watchdog.
[ OK ] Started Cisco nolan service.
[ OK ] Started Cisco nss service.
Starting Cisco S15platform...
Starting Cisco Kclick...
[*01/22/2025 09:58:37.2190] 13
[*01/22/2025 09:58:37.2910] Active version: 17.6.4.56
[*01/22/2025 09:58:37.2930] Backup version: 0.0.0.0
[*01/22/2025 09:58:37.4500] Loading BCM modules ...
[*01/22/2025 09:58:37.4500] Ignore pptp.ko
[*01/22/2025 09:58:37.4520] Ignore pktflow.ko
[*01/22/2025 09:58:37.4540] Ignore pktrunner.ko
[*01/22/2025 09:58:37.4560] Load bcmlibs.ko
[*01/22/2025 09:58:37.6170] BCMLIBS loaded...
[*01/22/2025 09:58:37.6280] Load wlcsm.ko
[*01/22/2025 09:58:37.6520] Load rdp_fpm.ko
[*01/22/2025 09:58:37.6960] Load bdmf.ko
[*01/22/2025 09:58:37.7210] Load proclikefs.ko
[*01/22/2025 09:58:37.7400] Load rdpa_gpl.ko
[*01/22/2025 09:58:37.7620] Load rdpa_gpl_ext.ko
[*01/22/2025 09:58:37.7790] Load rdpa.ko
[*01/22/2025 09:58:37.8430] Load rdpa_usr.ko
[*01/22/2025 09:58:37.8650] Load rdpa_mw.ko
[*01/22/2025 09:58:38.1670] RDP Physical address=0x82200000 Virtual address = 0xffffff8001c80000
[*01/22/2025 09:58:38.1800] configure_runner: NATC keysize 0x100070 key element size 16 contextsize 0x400000 context element size 64
[*01/22/2025 09:58:38.1800] ++++Runner gso_desc_pool created successfully
[*01/22/2025 09:58:38.2020] rdd_init_params.runner_nat_cache_key_ptr=0xffffffc003700000
[*01/22/2025 09:58:38.2020] rdd_init_params.runner_nat_cache_context_ptr=0xffffffc002e00000
[*01/22/2025 09:58:38.2020] rdd_init_params.runner_context_cont_ptr=0xffffffc003200000
[*01/22/2025 09:58:38.6670] FPM_BPM phy_addr 0x82c30000,virt_addr 0xffffff80018fe000
[*01/22/2025 09:58:38.6680]
[*01/22/2025 09:58:38.6680] RDP PKT memory = 64MB : Max Possible Bufs <16384> of size <4096>; Allocating <15360> bufs; RDP enum <5>
[*01/22/2025 09:58:38.8220] Load chipinfo.ko
[*01/22/2025 09:58:38.8290] brcmchipinfo: brcm_chipinfo_init entry
[*01/22/2025 09:58:38.8400] Load rdpa_cmd.ko
[*01/22/2025 09:58:38.8650] Load cmdlist.ko
[*01/22/2025 09:58:38.9420] Load bcm_enet.ko
[*01/22/2025 09:58:39.0950] crossbar Mux: connect cb_idx:0 int_ep 0 to ext_ep 0
[*01/22/2025 09:58:39.0950] crossbar Mux: connect cb_idx:0 int_ep 1 to ext_ep 2
[*01/22/2025 09:58:41.8150]
[*01/22/2025 09:58:41.8150] Authenticating ACT2 ID:C9120
[*01/22/2025 09:58:41.8150] Authenticating SN:FOC27253E8S
[*01/22/2025 09:58:41.8150] (ACT2Boot) Hardware is Cisco (c) authentic
[*01/22/2025 09:58:41.8210] Seeding /dev/urandom from ACT2
[*01/22/2025 09:58:43.3500] Reading ACT2 SUDI certificates
[*01/22/2025 09:58:44.0220] NOTE: Using Port Grouping for IMP ports : [ 0 --> 4 ] [ 1, 2 --> 5 ] [ 3, 7 --> 8 ]
[*01/22/2025 09:58:44.8310] eth0: Down <58:8B:1C:B6:3C:90> <ExtSw P0, Logical 08> PHY_ID <0x0007f008:0x08: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*01/22/2025 09:58:44.8310] eth1: Down <58:8B:1C:B6:3C:90> <ExtSw P1, Logical 09> PHY_ID <0x0007f009:0x09: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*01/22/2025 09:58:44.8310] eth2: Down <58:8B:1C:B6:3C:90> <ExtSw P2, Logical 10> PHY_ID <0x0007f00a:0x0a: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*01/22/2025 09:58:44.8310] eth3: Down <58:8B:1C:B6:3C:90> <ExtSw P3, Logical 11> PHY_ID <0x0007f00b:0x0b: On-chip 1G GPHY> Cfg: ANG.1G; Down
[*01/22/2025 09:58:44.8310] eth4: Down <58:8B:1C:B6:3C:90> <ExtSw P7, Logical 15>
[*01/22/2025 09:58:44.8310] Chip Port 9, CrossBar Port 0, PHY_ID <0x06100006:0x06: On-chip 2.5G SERDES> Cfg: ANG.2.5G; Down
[*01/22/2025 09:58:44.8310] PHY_ID <0x0388001f:0x1f:External Cascaded 10G EXT3> Cfg: ANG.2.5G; Down
[*01/22/2025 09:58:44.8310] ===> Activate Deep Green Mode
[*01/22/2025 09:58:44.8310] bcmswlpbk0 (Ext switch port: (Logical Port: Virtual link DOWN
[*01/22/2025 09:58:44.9130] bcm_enet_init:L2672 ENET system contructed and configured enet-kthrd thread
[*01/22/2025 09:58:44.9130] enet_kthread_handler:L326 Instantiating ENET thread
[*01/22/2025 09:58:44.9350] open </dev/fcache> error no 2
[*01/22/2025 09:58:44.9350] fcctl: failed to disable hw acceleration
[*01/22/2025 09:58:44.9350] fcctl: failed to configure Flow Cache
[*01/22/2025 09:58:44.9360] open </dev/fcache> error no 2
[*01/22/2025 09:58:44.9360] fcctl: failed to disable Flow Cache
[*01/22/2025 09:58:44.9370]
[*01/22/2025 09:58:44.9370] open </dev/fcache> error no 2
[*01/22/2025 09:58:44.9370] fcctl: failed to flush Flow Cache entries Broadcom Packet Flow Cache flushing the flows
[*01/22/2025 09:58:44.9510] Auto Detection of Serdes: Enabled
[*01/22/2025 09:58:44.9510] PHY Capabilities: 2.5GFD|1GFD|100MFD
[*01/22/2025 09:58:44.9510] Link is Down.
[*01/22/2025 09:58:45.0700] ret code = 0.
[*01/22/2025 09:58:45.0750] wired0 Link encap:Ethernet HWaddr 58:8B:1C:B6:3C:90
[*01/22/2025 09:58:45.0750] UP BROADCAST MULTICAST MTU:2044 Metric:1
[*01/22/2025 09:58:45.0750] RX packets:0 errors:0 dropped:0 overruns:0 frame:0
[*01/22/2025 09:58:45.0750] TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
[*01/22/2025 09:58:45.0750] collisions:0 txqueuelen:1000
[*01/22/2025 09:58:45.0750] RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
[*01/22/2025 09:58:45.0770] 58:8B:1C:B6:3C:90
[*01/22/2025 09:58:45.0770] BCM11ax AP: MIC Certificate Present
[*07/06/2023 23:59:59.0070] Last reload time: Jan 22 09:58:36 2025
[*01/22/2025 09:58:36.5370] Last reload reason : 0: unknown
[*01/22/2025 09:58:37.1410] Loading HND Module
[*01/22/2025 09:58:37.2900] stile module dp init successfully
[*01/22/2025 09:58:37.2900] NBAR Label:BLD_POLARIS_DEV_LATEST_20200414_053707 Module timestamp: Aug 10 2022 at 23:37:34 User: ttaichol
[*01/22/2025 09:58:38.2660]
[*01/22/2025 09:58:38.2660] ACT2 Check passed
[*01/22/2025 09:58:39.0720] Starting check if backup WiFi NVRAM are available
[*01/22/2025 09:58:39.0720] WiFi backup nvram - crc = 4155980973
[*01/22/2025 09:58:39.0720] WiFi active nvram - crc =617
[*01/22/2025 09:58:39.0720] [WARNING]ACTIVE and BACKUP NVRAM NOT use same data
[*01/22/2025 09:58:39.0900] restore done!
[*01/22/2025 09:58:39.0970] restore done!
Starting Cisco nolan USB service...
[ OK ] Started Cisco act2 check.
[ OK ] Started Cisco marlin_sia module service.
[ OK ] Started Cisco S15platform.
[ OK ] Started Cisco Kclick.
[ OK ] Started Cisco nolan USB service.
[ OK ] Started Cisco pre-PoE negotiation.
Starting Cisco pre-PoE negotiation...
Starting Cisco certificate create service...
Starting Cisco sysctl service...
[*01/22/2025 09:58:44.2010] sysctl: write error: Input/output error
Starting Cisco Sku service...
Starting Cisco ME service...
[ OK ] Started Cis[01/22/2025 09:58:44.4580] broadcomThermalDrv brcm-therm: init (CPU count 4 4 4 4)
[ OK ] Started Cisco sysctl service.
[ OK ] Started Cisco Sku service.
[ OK ] Started Cisco ME service.
[ OK ] Started Tam server.
Starting Tam server...
[*01/22/2025 09:58:44.7800] crypto worker thread started
[*01/22/2025 09:58:44.7820] crypto worker thread started
[*01/22/2025 09:58:44.8120] Broadcom EAP Forwarder v0.1 is loaded
[*01/22/2025 09:58:44.8610] igs_module_init:867: IGS 18 create network socket successful
Starting Cisco Tam service...rvice.
Starting Cisco certtime service...
Starting Cisco syslog service...
Starting Cisco S16platfomm...
Starting rsyslog client...
[ OK ] Started Cisco syslog service.
[*01/22/2025 09:58:45.2660] Wifi Forwarding Driver is initialized!
[*01/22/2025 09:58:45.5750] wl_module_init: passivemode set to 0x1
[*01/22/2025 09:58:45.5750] wl_module_init: txworkq set to 0x0
[*01/22/2025 09:58:45.5760] wl_pktfwd_sys_init: WL_PKTFWD[1.1.0] Success
[*01/22/2025 09:58:45.5800] initvars_cis_pci: Not CIS format
[*01/22/2025 09:58:45.5800] sprom_read_pci: buf[0] = 0xffff, returning bad-crc
[*01/22/2025 09:58:45.5800] srom read failed
[*01/22/2025 09:58:45.5800] srom rev:0
[*01/22/2025 09:58:45.5830] BME Service Initialization
[*01/22/2025 09:58:45.5830] BME: M2M Core id 0x844 rev 3
[*01/22/2025 09:58:45.5840] wl0: phy_radio_attach: RF Band Cap: 2G:1 5G:1
[*01/22/2025 09:58:45.6140] BME:register key<1010802> user RLM sel IDX set 1 mem 2 8 hi 0 0
[*01/22/2025 09:58:45.6140] wl0 taf_do_enable: TAF is enabled
[*01/22/2025 09:58:45.6160]
[*01/22/2025 09:58:45.6160] WLC_ATTACH routine completed successfully
[*01/22/2025 09:58:45.6160] wfd0-thrd WL 0 FLowControl total<111848> lo<27962> hi<11184> favor prio<4>
[*01/22/2025 09:58:45.6170] wfd_bind: wfd0-thrd initialized pktlists: radio 0 nodes 4104 xfer wl_pktfwd_xfer_callback+0x0/0x298 [wl]
[*01/22/2025 09:58:45.6170] Creating CPU ring for queue number 0 with 1024 packets descriptor=0xffffffbffd251680
[*01/22/2025 09:58:45.6170] Creating CPU ring for queue number 1 with 1024 packets descriptor=0xffffffbffd2516c0
[*01/22/2025 09:58:45.6170] wfd_bind: Dev apr1v0 wfd_idx 0 wl_radio_idx 0 Type skb:sll configured WFD thread wfd0-thrd minQId/maxQId (8/9), status (0) qmask 0x3
[*01/22/2025 09:58:45.6170] Instantiating WFD 0 thread
[*01/22/2025 09:58:45.6170] wl_wfd_bind: wl0 wfd_idx 0 success
[*01/22/2025 09:58:45.6170] eap_dev_g: initialized pktlists: radio 0 nodes 4104 xfer wl_pktfwd_xfer_callback+0x0/0x298 [wl]
[*01/22/2025 09:58:45.6170] 0 FlowControl total<111848> lo<27962> hi<11184> favor prio<4> enabled<1>
[*01/22/2025 09:58:45.6180] apr1v0: Broadcom BCM43684 802.11 Wireless Controller 17.20.10 (r790816 WLTEST)
[*01/22/2025 09:58:45.6220] initvars_cis_pci: Not CIS format
[*01/22/2025 09:58:45.6220] sprom_read_pci: buf[0] = 0xffff, returning bad-crc
[*01/22/2025 09:58:45.6220] srom read failed
[*01/22/2025 09:58:45.6220] srom rev:0
[*01/22/2025 09:58:45.6250] BME Service Initialization
[*01/22/2025 09:58:45.6250] BME: M2M Core id 0x844 rev 3
[*01/22/2025 09:58:45.6260] wl1: phy_radio_attach: RF Band Cap: 2G:1 5G:1
[*01/22/2025 09:58:45.6560] BME:register key<1010802> user RLM sel IDX set 1 mem 2 8 hi 0 0
[*01/22/2025 09:58:45.6560] wl1 taf_do_enable: TAF is enabled
[*01/22/2025 09:58:45.6570]
[*01/22/2025 09:58:45.6570] WLC_ATTACH routine completed successfully
[*01/22/2025 09:58:45.6580] wfd1-thrd WL 1 FLowControl total<111848> lo<27962> hi<11184> favor prio<4>
[*01/22/2025 09:58:45.6580] wfd_bind: wfd1-thrd initialized pktlists: radio 1 nodes 4104 xfer wl_pktfwd_xfer_callback+0x0/0x298 [wl]
[*01/22/2025 09:58:45.6580] Creating CPU ring for queue number 2 with 1024 packets descriptor=0xffffffbffd251700
[*01/22/2025 09:58:45.6580] Creating CPU ring for queue number 3 with 1024 packets descriptor=0xffffffbffd251740
[*01/22/2025 09:58:45.6580] wfd_bind: Dev apr0v0 wfd_idx 1 wl_radio_idx 1 Type skb:sll configured WFD thread wfd1-thrd minQId/maxQId (10/11), status (0) qmask 0xc
[*01/22/2025 09:58:45.6590] Instantiating WFD 1 thread
[*01/22/2025 09:58:45.6590] wl_wfd_bind: wl1 wfd_idx 1 success
[*01/22/2025 09:58:45.6590] eap_dev_g: initialized pktlists: radio 1 nodes 4104 xfer wl_pktfwd_xfer_callback+0x0/0x298 [wl]
[*01/22/2025 09:58:45.6590] 1 FlowControl total<111848> lo<27962> hi<11184> favor prio<4> enabled<1>
[*01/22/2025 09:58:45.6600] apr0v0: Broadcom BCM43684 802.11 Wireless Controller 17.20.10 (r790816 WLTEST)
[*01/22/2025 09:58:45.8890] pid 3461's current affinity mask: f
[*01/22/2025 09:58:45.8890] pid 3461's new affinity mask: e
[*01/22/2025 09:58:45.8900] pid 3453's current affinity mask: f
[*01/22/2025 09:58:45.8900] pid 3453's new affinity mask: e
[*01/22/2025 09:58:45.9460] wl: Not up
[*01/22/2025 09:58:45.9480] wl: Not up
[*01/22/2025 09:58:45.9550] wl: Bad Band
[*01/22/2025 09:58:45.9620] Success.
[*01/22/2025 09:58:45.9630] Success.
[*01/22/2025 09:58:47.2440]
[*01/22/2025 09:58:47.2440] Click sched monitor: schedulers = 1
[ OK ] Started Cisco S16platfomm.
[ OK ] Started rsyslog client.
Starting RHL daemon...
Starting Cisco synclogd...
[*01/22/2025 09:58:50.8300] rhl_reset : got minor 55
[ OK ] Started Cisco synclogd.
[01/22/2025 09:58:51.0660] NXP-RHL-Driver 0001:01:00.0: RHL: AP SKU = 1, pow min,max = -4, 20
[01/22/2025 09:58:51.0660] , Rx Diversity =0, 6g AP = 0, Ithaca Esku =0
[01/22/2025 09:58:51.2660] NXP-RHL-Driver 0001:01:00.0: Final VSPA image size val 0x1086000
[01/22/2025 09:58:52.1600] bcm963xx-pcie: RHL legacy interrupt initialized
[ OK ] Started RHL daemon.
[** ] A start job is running for Cisco certtime service (37s / 2min 19s)[*01/22/2025 09:58:51.3570] V2H call back init
[*01/22/2025 09:58:51.3570] V2H callback registered
[ OK ] Started Cisco certtime service.
[ OK ] Reached target System Initialization.
j▒▒5▒j OK ] Reached target Basic System.
Starting Security Auditing Service...
[ OK ] Started NTP_PROC daemon.
Starting NTP_PROC daemon...
[ OK ] Started RHL monitor/reset daemon.
[*01/22/2025 09:59:41.7460] watchdogd: reading file /click/wdog_helper/ap_monproc_kclick: No such file or directory
[*01/22/2025 09:59:41.7460] !!!!! {watchdogd} reading /click/wdog_helper/ap_monproc_kclick failed [2]: No such file or directory
[*01/22/2025 09:59:41.7460] !!!!! {watchdogd} Process kclick no heartbeat for 60s
[*01/22/2025 09:59:41.7460] !!!!! {watchdogd} Process sxpd gone for 60s
[*01/22/2025 09:59:41.7500] watchdogd: reading file /tmp/brain_dump: No such file or directory
[*01/22/2025 09:59:41.7500] watchdogd: reading file /click/l2_l3_gateway/gateway_ip_addr: No such file or directory
[*01/22/2025 09:59:46.4680] No certificates found.
[*01/22/2025 09:59:46.8350] reset device opened
Starting RHL monitor/reset daemon...
J▒▒▒&j OK ] Reached target Login Prompts.
Starting Cisco rtd service...
[ OK ] Started System Monitor service.
[*01/22/2025 09:59:47.9850] root: Systemd memory leak found Rss=8544, doing systemctl daemon-reexec
#Starting System Monitor service...
Starting Cisco printkd...
Starting RSYNC User Key Generation...
Starting Sensord daemon...
Starting Hostapd process...
Starting gRPC server daemon...
Starting Cisco brain service...
Starting Cisco klogd...
Starting Fast CGI daemon...
Starting Cisco led service...
[*01/22/2025 09:59:48.5700] EEPROM Size = 65536
[*01/22/2025 09:59:48.5700] loading pow table from EEPROM▒ Starting Clean Air daemon...
Starting Cisco kexec...
Starting AP Trace daemon...
Starting capwapd...
Starting BLE init service...
Starting WCPD process...
Starting Cisco image/firmware updater service...
[*01/22/2025 09:59:48.9300]
[*01/22/2025 09:59:48.9300] [1/22/2025 9:60:49] updt_util: PHY firmware is up to date
[*01/22/2025 09:59:48.9380]
[*01/22/2025 09:59:48.9380] [1/22/2025 9:60:49] updt_util: All bootloaders are up to date
[ OK ] Started Cisco printkd.
[ OK ] Started RSYNC User Key Generation.
[ OK ] Started Cisco klogd.
[ OK ] Started Cisco led service.
[ OK ] Started Cisco kexec.
[ OK ] Started BLE init service.
[ OK ] Started Cisco image/firmware updater service.
[*01/22/2025 09:59:49.6380] Failed to get properties: Connection reset by peer
[*01/22/2025 09:59:49.6430] Failed to get D-Bus connection: No such file or directory
[*01/22/2025 09:59:49.7470] Failed to get properties: Connection reset by peer
[*01/22/2025 09:59:49.7490] Failed to get properties: Connection reset by peer
[*01/22/2025 09:59:49.7500] Failed to get properties: Connection reset by peer
[ OK ] Started AP Trace daemon.
[ OK ] Started Fast CGI daemon.
[ OK ] Started Cisco rtd service.
Starting ntp file watcher...
[ OK ] Reached target sshd-keygen.target.
Starting OpenSSH server daemon...
[ OK ] Started Sensord daemon.
[*01/22/2025 09:59:49.9630] No valid NTP source
[*01/22/2025 09:59:49.9630] No valid ntp server info file. Stop NTP!
Starting ntp watcher...
[ OK ] Started OpenSSH server daemon.
[ OK ] Started ntp file watcher.
[ OK ] Started ntp watcher.
[*01/22/2025 09:59:50.0780] hostapd:Hostapd: DCDS not init cloud=0 webauth=255 255 init=0
[ OK ] Started Cisco brain service.
[ OK ] Started Hostapd process.
Starting dnsmasq watcher...
Starting DNSmasq...
[ OK ] Started DNSmasq.
[ OK ] Started dnsmasq watcher.
User Access Verification
Username: [*01/22/2025 09:59:50.7120] EEPROM Size = 65536
[*01/22/2025 09:59:50.7120] loading trx table from EEPROM to DTCM
[*01/22/2025 09:59:50.7120] 24480 bytes copied from RHL EEPROM to DTCM
[*01/22/2025 09:59:50.7120] loading ro1 table from EEPROM to DTCM
[*01/22/2025 09:59:50.7120] 12240 bytes copied from RHL EEPROM to DTCM
[*01/22/2025 09:59:50.7120] loading ro2 table from EEPROM to DTCM
[*01/22/2025 09:59:51.1350] click-config/io-real.click:382: While configuring 'todev_wired0 :: ToDevice':
[*01/22/2025 09:59:51.1350] warning: device 'wired0' is down
[*01/22/2025 09:59:51.2260] click-config/io-real.click:382: While configuring 'fromdev_wired0 :: FromWiredSwNssDevice':
[*01/22/2025 09:59:51.2260] warning: device 'wired0' is down
[*01/22/2025 09:59:51.5990] click-config/io-real.click:382: While initializing 'tohost_wired0 :: ToHost':
[*01/22/2025 09:59:51.5990] warning: device 'wired0' is down
Starting Lighttpd Watcher...
[ OK ] Started Lighttpd Watcher.
Stopping DNSmasq...
[ OK ] Stopped DNSmasq.
Starting DNSmasq...
Starting dhcpv6 client watcher...
[*01/22/2025 09:59:51.9040] ip6_port srcr2, ip6local ::, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
Starting DHCPv6 client...
[ OK ] Started DHCPv6 client.
[ OK ] Started dhcpv6 client watcher.
[*01/22/2025 09:59:52.5050] pid 5904's current affinity mask: f
[*01/22/2025 09:59:52.5050] pid 5904's new affinity mask: 2
[ OK ] Started gRPC server daemon.
[ OK ] Started WCPD process.
[ OK ] Started Clean Air daemon.
[*01/22/2025 09:59:53.2040] WCP: Opening /var/platform/num_wan_ports failed!
[*01/22/2025 09:59:53.2390] DOT11_TXP[0]:Domain configured: 50 class:F
[*01/22/2025 09:59:53.3700] starting tam services using ACT2...
[*01/22/2025 09:59:53.3700] TAM init done
[*01/22/2025 09:59:53.4280] DOT11_TXP[0]:Domain configured: 49 class:F
[*01/22/2025 09:59:53.5750] DOT11_TXP[1]:Domain configured: 50 class:F
[ OK ] Started capwapd.
[*01/22/2025 09:59:54.1480] DOT11_DRV[0]: BCM FIPS POST for CCMP-128 and GCMP-128 passed
[*01/22/2025 09:59:54.1540] DOT11_DRV[0]: Stop Radio0
[*01/22/2025 09:59:54.1550] Stopped Radio 0
[*01/22/2025 09:59:54.1800] ID (ID/0) INDONESIA
[*01/22/2025 09:59:54.1870] DOT11_DRV[0]: set_channel Channel set to 6/20
[*01/22/2025 09:59:54.4030] chpasswd: password for user changed
[*01/22/2025 09:59:54.9440] capwapd: reading file /click/nss_lag_control/lacp_state: No such file or directory
[*01/22/2025 09:59:54.9440] !!!!! {/opt/cisco/bin/capwapd} reading /click/nss_lag_control/lacp_state failed [2]: No such file or directory
[*01/22/2025 09:59:54.9440] capwapd: reading file /click/nss_lag_control/capwap_state: No such file or directory
[*01/22/2025 09:59:54.9440] !!!!! {/opt/cisco/bin/capwapd} reading /click/nss_lag_control/capwap_state failed [2]: No such file or directory
[*01/22/2025 09:59:55.1340] USB Device Disconnected from the AP
[*01/22/2025 09:59:55.3130] DOT11_DRV[1]: BCM FIPS POST for CCMP-128 and GCMP-128 passed
[*01/22/2025 09:59:55.3130] DOT11_DRV[1]: Stop Radio1
[*01/22/2025 09:59:55.3130] Stopped Radio 1
[*01/22/2025 09:59:55.3360] ID (ID/0) INDONESIA
[*01/22/2025 09:59:55.3420] DOT11_DRV[1]: set_channel Channel set to 149/20
[*01/22/2025 09:59:56.1100] DOT11_DRV[2]: off_channel timeout but no req in progress
[ OK ] Started Security Auditing Service.
[ OK ] Reached target Multi-User System.
[*01/22/2025 09:59:56.8520] size: 17508 bytes (48028 left)
[*01/22/2025 09:59:57.0680] DOT11_DRV[0]: set_channel Channel set to 1/20
[*01/22/2025 09:59:57.2760] wl: Unsupported
[*01/22/2025 09:59:58.0490] DOT11_DRV[0]: set_channel Channel set to 1/20
[*01/22/2025 09:59:58.2670] wl: Unsupported
[*01/22/2025 09:59:59.0310] DOT11_DRV[0]: set_channel Channel set to 1/20
[*01/22/2025 09:59:59.3340] DOT11_DRV[0]: set_channel Channel set to 1/20
[*01/22/2025 09:59:59.5530] wl: Unsupported
[*01/22/2025 10:00:00.7100] DOT11_DRV[0]: set_channel Channel set to 1/20
[*01/22/2025 10:00:01.9760] size: 17508 bytes (48028 left)
[*01/22/2025 10:00:02.1900] DOT11_DRV[1]: set_channel Channel set to 149/20
[*01/22/2025 10:00:02.3950] wl: Unsupported
[*01/22/2025 10:00:03.2100] DOT11_DRV[1]: set_channel Channel set to 149/20
[*01/22/2025 10:00:04.2900] DOT11_DRV[1]: set_channel Channel set to 149/20
[*01/22/2025 10:00:05.4050] DOT11_DRV[1]: set_channel Channel set to 149/20
[*01/22/2025 10:00:05.6080] DOT11_DRV[1]: set_channel Channel set to 149/20
[*01/22/2025 10:00:07.2780] DOT11_DRV[1]: set_channel Channel set to 149/20
sensord psage_base init: RHB Sage base ptr a1030000
sensord split_glue psage_base: RHB Sage base ptr a1030000
sensord split_glue sage_addr: RHB Sage base ptr a1030000
sensord crim: RHB Sage base ptr a1030000
I am trying to factory reset too, and it's nothing change. I also trying to connect to my router ISP to Cisco 9120AXE-F and then it detect and get the ip but i can't setup, on the console it display like this :
% Authentication failed
Username:
[*01/22/2025 10:33:12.5130] CAPWAP State: Discovery
[*01/22/2025 10:33:12.5240] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:33:12.5260] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:33:22.0190]
[*01/22/2025 10:33:22.0190] CAPWAP State: Discovery
[*01/22/2025 10:33:22.0210] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:33:22.0220] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:33:31.5190]
[*01/22/2025 10:33:31.5190] CAPWAP State: Discovery
[*01/22/2025 10:33:31.5210] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:33:31.5220] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:34:25.9930] PNP:Server not reachable, Start CAPWAP Discovery
[*01/22/2025 10:34:25.9930] Going to restart CAPWAP (reason : Post startCapwapDi scovery)...
[*01/22/2025 10:34:25.9930] Restarting CAPWAP State Machine.
[*01/22/2025 10:34:25.9930] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in C APWAP state: Discovery(2).
[*01/22/2025 10:34:26.0140]
[*01/22/2025 10:34:26.0140] CAPWAP State: DTLS Teardown
[*01/22/2025 10:34:26.1660] status 'upgrade.sh: Script called with args:[CANCEL] '
[*01/22/2025 10:34:26.2190] do CANCEL, part1 is active part
[*01/22/2025 10:34:26.2460] status 'upgrade.sh: Cleanup tmp files ...'
[*01/22/2025 10:34:26.2760] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in C APWAP state: DTLS Teardown(4).
[*01/22/2025 10:34:30.8330]
[*01/22/2025 10:34:30.8330] CAPWAP State: Discovery
[*01/22/2025 10:34:30.8350] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:34:30.8460] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:34:40.3190]
[*01/22/2025 10:34:40.3190] CAPWAP State: Discovery
[*01/22/2025 10:34:40.3260] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:34:40.3270] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:34:49.8220]
[*01/22/2025 10:34:49.8220] CAPWAP State: Discovery
[*01/22/2025 10:34:49.8240] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:34:49.8260] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:34:59.3250]
[*01/22/2025 10:34:59.3250] CAPWAP State: Discovery
[*01/22/2025 10:34:59.3270] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:34:59.3330] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:35:08.8280]
[*01/22/2025 10:35:08.8280] CAPWAP State: Discovery
[*01/22/2025 10:35:08.8300] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:35:08.8310] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
▒[*01/22/2025 10:36:40.2270] Set PnP NTP Server pnpserver.
[*01/22/2025 10:38:10.3440] PNP:Server not reachable, Start CAPWAP Discovery
[*01/22/2025 10:38:10.3440] Going to restart CAPWAP (reason : Post startCapwapDi scovery)...
[*01/22/2025 10:38:10.3440] Restarting CAPWAP State Machine.
[*01/22/2025 10:38:10.3440] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in C APWAP state: Discovery(2).
[*01/22/2025 10:38:10.3630]
[*01/22/2025 10:38:10.3630] CAPWAP State: DTLS Teardown
[*01/22/2025 10:38:10.4660] status 'upgrade.sh: Script called with args:[CANCEL] '
[*01/22/2025 10:38:10.5330] do CANCEL, part1 is active part
[*01/22/2025 10:38:10.5530] status 'upgrade.sh: Cleanup tmp files ...'
[*01/22/2025 10:38:10.5840] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in C APWAP state: DTLS Teardown(4).
[*01/22/2025 10:38:15.0990]
[*01/22/2025 10:38:15.0990] CAPWAP State: Discovery
[*01/22/2025 10:38:15.1010] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:38:15.1020] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:38:24.5860]
[*01/22/2025 10:38:24.5860] CAPWAP State: Discovery
[*01/22/2025 10:38:24.5880] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:38:24.5890] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:38:34.0890]
[*01/22/2025 10:38:34.0890] CAPWAP State: Discovery
[*01/22/2025 10:38:34.0950] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:38:34.0970] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:38:43.5920]
[*01/22/2025 10:38:43.5920] CAPWAP State: Discovery
[*01/22/2025 10:38:43.6030] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:38:43.6040] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:38:53.0950]
[*01/22/2025 10:38:53.0950] CAPWAP State: Discovery
[*01/22/2025 10:38:53.1010] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:38:53.1030] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:39:30.4580] Set PnP NTP Server pnpserver.
[*01/22/2025 10:41:00.5740] PNP:Server not reachable, Start CAPWAP Discovery
[*01/22/2025 10:41:00.5740] Going to restart CAPWAP (reason : Post startCapwapDi scovery)...
[*01/22/2025 10:41:00.5740] Restarting CAPWAP State Machine.
[*01/22/2025 10:41:00.5740] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in C APWAP state: Discovery(2).
[*01/22/2025 10:41:00.5950]
[*01/22/2025 10:41:00.5950] CAPWAP State: DTLS Teardown
[*01/22/2025 10:41:00.7110] status 'upgrade.sh: Script called with args:[CANCEL] '
[*01/22/2025 10:41:00.7640] do CANCEL, part1 is active part
[*01/22/2025 10:41:00.7860] status 'upgrade.sh: Cleanup tmp files ...'
[*01/22/2025 10:41:00.8170] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in C APWAP state: DTLS Teardown(4).
[*01/22/2025 10:41:05.2010]
[*01/22/2025 10:41:05.2010] CAPWAP State: Discovery
[*01/22/2025 10:41:05.2030] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:41:05.2040] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:41:14.6920]
[*01/22/2025 10:41:14.6920] CAPWAP State: Discovery
[*01/22/2025 10:41:14.7040] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:41:14.7050] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:41:24.1900]
[*01/22/2025 10:41:24.1900] CAPWAP State: Discovery
[*01/22/2025 10:41:24.1920] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:41:24.1930] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:41:33.6930]
[*01/22/2025 10:41:33.6930] CAPWAP State: Discovery
[*01/22/2025 10:41:33.7000] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:41:33.7010] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:41:43.1960]
[*01/22/2025 10:41:43.1960] CAPWAP State: Discovery
[*01/22/2025 10:41:43.1970] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:41:43.1990] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:43:14.7380] Set PnP NTP Server pnpserver.
[*01/22/2025 10:44:44.8540] PNP:Server not reachable, Start CAPWAP Discovery
[*01/22/2025 10:44:44.8540] Going to restart CAPWAP (reason : Post startCapwapDi scovery)...
[*01/22/2025 10:44:44.8540] Restarting CAPWAP State Machine.
[*01/22/2025 10:44:44.8540] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in C APWAP state: Discovery(2).
[*01/22/2025 10:44:44.8770]
[*01/22/2025 10:44:44.8770] CAPWAP State: DTLS Teardown
[*01/22/2025 10:44:44.9990] status 'upgrade.sh: Script called with args:[CANCEL] '
[*01/22/2025 10:44:45.0510] do CANCEL, part1 is active part
[*01/22/2025 10:44:45.0720] status 'upgrade.sh: Cleanup tmp files ...'
[*01/22/2025 10:44:45.1030] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in C APWAP state: DTLS Teardown(4).
[*01/22/2025 10:44:49.6580]
[*01/22/2025 10:44:49.6580] CAPWAP State: Discovery
[*01/22/2025 10:44:49.6600] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:44:49.6610] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:44:59.1440]
[*01/22/2025 10:44:59.1440] CAPWAP State: Discovery
[*01/22/2025 10:44:59.1460] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:44:59.1470] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:45:08.6520]
[*01/22/2025 10:45:08.6520] CAPWAP State: Discovery
[*01/22/2025 10:45:08.6540] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:45:08.6550] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:45:18.1500]
[*01/22/2025 10:45:18.1500] CAPWAP State: Discovery
[*01/22/2025 10:45:18.1520] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:45:18.1630] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:45:27.6530]
[*01/22/2025 10:45:27.6530] CAPWAP State: Discovery
[*01/22/2025 10:45:27.6590] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*01/22/2025 10:45:27.6610] Discovery Request sent to ff02::18c, discovery type UNKNOWN(0)
[*01/22/2025 10:46:04.9620] Set PnP NTP Server pnpserver.
What happen on this device and how to fix this?
7 Replies 7
Mark Elsen
 - What is the intended use for this AP , because it looks like it is trying to find a controller ?
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I just want to configure the AP to get bridge mode and spreading the wifi signal, is that necessary for configure using the controller? what if i don't have it? is there any alternative solution? because I am trying to install virtual controller air-ctvm-k9 from my vmware  and it connected to my isp router which mean it is one segment on my AP but the virtual controller not able to find the AP.
              - What software version is the virtual controller running ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I think from this link https://upw.io/4tv/AIR_CTVM-K9_8_5_161_0.ova the version is 8.5.161.0 because i was following this tutorial https://www.youtube.com/watch?v=YNB-sppMizU for installation of virtual controller
  - Ref : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
    The   9120AXE model will need at least 8.10.181.0 (or above) on the virtual controller. Your current  version 8.5.161.0
    is too old ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I am already install the virtual wireless controller version 8.10.183.0 but it still same result
My cisco virtual wlc IP is 192.168.1.6
My cisco AP in same network in 192.168.1.5 same as my ISP Router. I'm trying to reset my AP too but no luck.
  - Is there anything in the logs of the controller when the AP tries  to join ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
