Hi all,
Can anyone give me some orientation how the radius auth process/handshake between the WLC and ISE changes once the F5 is installed in the middle in order to perform load balancing?
We can do some kind of load balancing by configuring different radius servers on each WLC for which, I must configure the same shared secret in the WLC and ISE so the radius request/accept could be processed.
Now that we have the F5 in the middle, do I need to create/configure the same shared secret in the F5 so radius transactions can be processed by this device?. Based on the following link, I must configure the F5 in the ISE like another NAD device (similar to the WLC) but I do not know if this additional configuration in the ISE includes the Auth parameter to be added in the ISE NAD (F5) configuration.
How to properly use a load balancer in Cisco's Identity Services Engine
http://www.networkworld.com/community/blog/load-balancing-cisco-identity-services-engine
Our sheme is shown next,
