question on radius and wlc- managment users vs wireless domain users
George Wolf
Currently I have a wlc working perfectly with manamgnet via web login local and wireless users sent to the Radius server.  This works fine but we need to take it a step farther and get our management users authenticating.
I see how I am able to checkbox the management interface to authenticate management users but am concerned if I do so all the wireless users will be able to get into the box.
How do you make it so requests from the management go to a specific group and all wireless users go to domain users?  We are running and IAS server.  I've seen many docs that tell you one or the other but none explain how you make both work properly.
any help appreciated- thanks
geo
Ric Beeching
Level 7
Level 7
It is more common to use AAA/TACACS for your mgmt users and RADIUS for your wireless authentication but depends on your available resources. If you do have to use RADIUS then you will just manage that level of access through attributes on your RADIUS server.
For example, this is an old guide but the ACS server is configured to return an attribute to the WLC allowing the user to logon to the WLC as a mangement user. If that attribute was not returned the user would be denied management access.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/71989-manage-wlc-users-radius.html
Ric
Please rate helpful / correct posts
