Question with ASA upgrade IPS fimware without s sharesupport
Hi Everebody
I'm doing a design which is the number of part-IPS-K9 ASA5525
but I need;
3 years of update signatures (updates)
And
smarnet only one year.
SP-SFSW-A25IPS9 is assumed that this part number includes the two services, but I can not separate, What would be the part number for the smarnet (sharesupport) and which the signature updates. SEPARATE =?
or go together?
Kind Regards!
Scott Fella
I would move your thread to the security
Firewall forum as the can help you out. This forum you posted on is more for wireless.
-Scott
Hi Scott
Thanks, I check with cisco equipment, and you can not separate it has to take together
Kind Regards!
