"wlan disable all" command --> will it kill my remote access?
Dean Romanelli
Level 4
Level 4
Hi All,
I am having an issue with one of my WLC's in a remote part of the world. The issues started after I changed the management IP address. After the change, I can no longer access the GUI. I can get in via telnet, but I have to clear arp on my local PC's IP and immediately telnet to the WLC for it to work, and I only get about 45 seconds of access before it shuts me out. Very strange since my PC is 4,000+ miles away.
I want to roll back to the old management IP to try and reverse troubleshoot this, but since I don't have GUI access, I have to put the command in on the CLI.  When I enter the command to change it: config interface address management 192.168.159.5 255.255.255.0 192.168.159.1 it says "failed: wlans are using this IP, disable wlans first."  However, when I show the wlans, the staff one shows interface name is "management," which is the interface that has the IP I want to change.
(Cisco Controller) >show wlan summary
Number of WLANs.................................. 3
WLAN ID  WLAN Profile Name / SSID               Status    Interface Name
1        Scrubbed - Staff / Scrubbed - Staff        Enabled    management
2        Scrubbed - Mobile / Scrubbed - Mobile  Enabled   fc_external
3        Scrubbed - Guest / Scrubbed - Guest  Enabled     fc_external
Can I do wlan disable all and remain connected to the WLC? My telnet access is coming from a VPN in the US and over MPLS to a router at the site in the remote country, so I'm not connected to it via wireless to my knowledge, but that "interface name: management" above has me second guessing this decision.
The WLAN's has no affect on your telnet session unless your associated to an access point, which you are not.
-Scott
-Scott
9 Replies 9
Scott Fella
Try this first:
config network mgmt-via-dynamic-interface enable
Then GUI using the ip of one of the dynamic interfaces.  Then look at what you changed or revert it back.
-Scott
-Scott
Hi Scott,
Does that make the mgmt interface pull down a DHCP address?  If so, how will I know what the IP is to GUI to?
No... I'm assuming you have created other interfaces on the WLC?  If so, then if you issue a show interface summary, you can GUI to any of the dynamic interface IP address.
-Scott
-Scott
I'm not entirely sure to be honest, as I inherited this piece of equipment - it is someone else's work.  I have the following:
(Cisco Controller) >show interface summary
 Number of Interfaces.......................... 3
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
fc_external                      2    untagged         192.168.1.3          Dynamic No     No
management                       1    untagged     192.168.158.100 Static  Yes    No
virtual                          N/A  N/A                        1.1.1.1              Static       No     No
My VPN tunnel originates in the US, where I am sitting to that 158 subnet at the site, and adding access to that 192.168.1.3 that is sitting on the dynamic interface isn't something I can do as that subnet (192.168.1.x) lives elsewhere as well from the data center's perspective. Hopefully that makes sense.  The setup is not ideal currently. I need to change it but for now I'm stuck.
Well go ahead and issue the config wlan disable all.  That way you can change the ip back.
-Scott
-Scott
Will I stay connected via telnet though once the wlans are disabled? I mean, I don't see why I wouldn't, that Staff wlan saying "management" is just giving me reservations.
What if I do reset system in 10 no-swap save-config first?  That way if I shut myself out, it will reboot in 10 minutes?  That won't factory default it right? Just "reloads" it more or less?
-Scott
-Scott
Thanks Scott. As it turns out, the WLC lost power that night and came back with the old IP.
Abhishek Abhishek
Yes, its correct as "wlan disable all" command will not kill any remote access like Telnet.
