Radio Failure
jkay18041
Level 6
Level 6
I just bought a cisco 1141n to play with and when i turned it on the logging on the console said "Interface Dot11Radio0: not starting because stop-on-failure set"
I am also getting insufficient power message. using a 3500yl from hp that is poe so not sure what my issue is.
Is this just because I have not set it up yet or is the radio actually dead?
*Mar  1 00:00:16.020: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firmware file (flash:/8001.img) was found
This is the reason why your 802.11b radio won't come up.  The radio-specific firmware is missing.
Most effective way is to overwrite and unpack the entire TAR file.  So let the AP boot normally.  Don't worry about the radio for the time being.
Make sure you have the TAR file located in the correct folder of your TFTP server.  Use the command "archive download-sw /over /force tftp://<TFTP IP address>/filename.tar".
Once the process is complete the AP will reboot.
12 Replies 12
Rasika Nayanajith
You can try to upgrade your AP firmware & that could fix the above issue.
Rasika
**** Pls rate all useful responses ****
Hi Rasika,
Can you please comment on below post.
https://supportforums.cisco.com/discussion/12301836/config-change-alert-wlc#comment-9949491
Hi Nomair,
As requested I have posted my input for the given thread.
Hope that is useful 🙂
Rasika
Leo Laohoo
Post the entire bootup process.  I want to see what is going on.
Passed.
IOS Bootloader - Starting system.
FLASH CHIP:  Numonyx P33
Checking for Over Erased blocks
Xmodem file system is available.
DDR values used from system serial eeprom.
WRDTR,CLKTR: 0x87000800, 0x40000000
RQDC, RFDC : 0x80000036, 0x0000020a
PCIE0: link is up.
PCIE0: VC0 is active
PCIE1: link is NOT up.
PCIE1 port 1 not initialized
PCIEx: initialization done
flashfs[0]: 10 files, 4 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 17725440
flashfs[0]: Bytes available: 14659584
flashfs[0]: flashfs fsck took 39 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: fc:99:47:d5:21:93
Ethernet speed is 1000 Mb - FULL duplex
Loading "flash:/c1140-k9w7-mx.152-4.JB5"...##########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################
File "flash:/c1140-k9w7-mx.152-4.JB5" uncompressed and installed, entry point: 0x4000
executing...
enet halted
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 15.2(4)JB5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 01-May-14 23:09 by prod_rel_team
Initializing flashfs...
flashfs[3]: 10 files, 4 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 32126976
flashfs[3]: Bytes used: 17725440
flashfs[3]: Bytes available: 14401536
flashfs[3]: flashfs fsck took 12 seconds.
flashfs[3]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 1 seconds.
flashfs[4]: Initialization complete....done Initializing flashfs.
Radio0  present 8363 8000 90020000 0 90030000 B
Rate table has 236 entries (16 legacy/0 11n/220 11ac)
POWER TABLE FILENAME = flash:/A5.bin
Radio1 not present 0 0 0 0 0 0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-AP1141N-A-K9 (PowerPC405ex) processor (revision A0) with 90102K/40960K bytes of memory.
Processor board ID FTX1639K3UF
PowerPC405ex CPU at 586MHz, revision number 0x147E
Last reset from watchdog timer expired
1 Gigabit Ethernet interface
1 802.11 Radio
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: FC:99:47:D5:21:93
Part Number                          : 73-12836-05
PCA Assembly Number                  : 800-33767-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC1634D80H
Top Assembly Part Number             : 800-33776-04
Top Assembly Serial Number           : FTX1639K3UF
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1141N-A-K9
Domain server mapped address 10.1.1.84 to ap
Press RETURN to get started!
*Mar  1 00:00:14.872: %IFMGR-7-NO_IFINDEX_FILE: Unable to open nvram:/ifIndex-table No such file or directory
*Mar  1 00:00:14.875: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (11)
*Mar  1 00:00:14.878: *** CRASH_LOG = YES
*Mar  1 00:00:15.178: Port 1 is not present
*Mar  1 00:00:16.020: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio0 due to get code failed: firmware file not found
*Mar  1 00:00:16.162: %DOT11-2-NO_PWR_TBL: Interface Dot11Radio0, no radio Power Table file (flash:/A5.bin) was found
*Mar  1 00:00:16.162:  FREE PWR TABLESBase Ethernet MAC address: FC:99:47:D5:21:93
*Mar  1 00:00:16.283: initializing dot11 onplus
*Mar  1 00:00:16.322: Unsupported radio found of type 0
*Mar  1 00:00:16.514: not a autoconfig enabled device!!!
*Mar  1 00:00:18.335: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:19.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:28.700: AUTOINSTALL: GigabitEthernet0 is assigned 10.1.1.84
*Mar  1 00:07:14.062: Starting Ethernet promiscuous mode
*Mar  1 00:07:14.195: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Mar  1 00:07:15.195: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:07:19.749: %SYS-5-RESTART: System restarted --
*Mar  1 00:07:19.749: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a cold start
*Mar  1 00:07:20.775: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:07:27.232: %EVT-4-WRN: Write of flash:/event.r0 done
*Mar  1 00:07:27.410: mvl_radio_coredump: Last reset code: 37; hostmem ptr 00000000
*Mar  1 00:07:27.414: Writing radio coredump to 'flash:/r0.rcore', flags 1
*Mar  1 00:07:27.414: Free space on flash for radio core dump: 13353128
*Mar  1 00:07:28.836: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.1.1.84, mask 255.255.255.0, hostname ap
Loading pxelinux.0 from 10.1.1.142 (via BVI1): !
[OK - 26970 bytes]
j$|
% Invalid input detected at '^' marker.
*Mar  1 00:07:35.924: %PARSER-4-BADCFG: Unexpected end of configuration file.
*Mar  1 00:07:35.924: %SYS-5-CONFIG_I: Configured from tftp://squid-01-wic.mlebk.local/pxelinux.0 by console
*Mar  1 00:07:39.416: Cmd Timeout After 12s
*Mar  1 00:07:39.416: mvl_handle_timeout called cmdtype=[0x26]
*Mar  1 00:07:39.416: FW coredump command failed 0/0.
*Mar  1 00:07:39.416: No coredump info received from firmware
*Mar  1 00:07:39.421: Interface Dot11Radio0: not starting because stop-on-failure set
I found what my problem is. I downloaded the firmware but it was in a .tar archive. so i opened up the archive and only copied the ios image, not the radio firmware and a few other drivers/files....so my question is how can i copy the entire .tar archive using xmodem to the AP and have it extract on its own? Or do I need to copy each file individually and do mkdir on the flash to create it?
Thanks for the help
will the same command work with xmodem? for some reason I cannot get this AP to talk to the network. So I'm using xmodem. If not where could I find a command that would do the same thing over the xmodem.
Thank you for your help
You can try mode button option to see if that works. In that case you need to rename your file as "c1140-k9w7-tar.default"
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Give it a go & see.
Rasika
Your AP has booted up fine (except for the radio not working).  Using XModem is slow and you're not going to fix anything because XModem you'll be downloading the BIN file.
Boot the AP normally and use the method I've posted above.
Check the attachment.
SumitKumar6282
Community Member
Upgrade the firmware from your WLController, reboot it. You'll get rid of it.
