Radio interfaces of AP are down
Noovi
Hi Guys,
i am having one light weight Access Point of model 3802. It is associated to WLC but its radio intrfaces are down. Pleae refer attached snaps.
i tried to disable and enable radios from WLC end but still its operational status is shwoing down.
Any idea if it is hardware issue or any solution to make them up?
5 Replies 5
Leo Laohoo
What firmware is the controller on?
8.3.143.0
Is the AP status Disabled?
Mark Elsen
          - Reboot the AP , and just after startup logon to it and check the logs (show logging) ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Noovi
Issue resolved by connectingPower injector to AP. It seems switch was not providing enough power to AP through PoE
