03-15-2024 10:05 AM
Im working connect an AP 1552 to 5508 HA-pair but despite that I added MAC to auth-list I'm receiving this message, I have been able to connect a lot of the same model without issues.
Join phase statistics
- Join requests received................................... 180
- Successful join responses sent........................... 180
- Unsuccessful join request processing..................... 180
- Reason for last unsuccessful join attempt................ RADIUS authorization is pending for the AP
- Time at last successful join attempt..................... Mar 15 16:09:35.639
- Time at last unsuccessful join attempt................... Mar 15 16:09:35.638
WLC is working with
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.160.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Any idea what additional can I do to get them connected?
as you can see they dont finish to join
MIC have been aggregated
03-15-2024 10:29 AM
- Check these advisories : https://community.cisco.com/t5/wireless/ap-not-able-join-to-wlc/m-p/2375540#M117738
M.
03-15-2024 10:40 AM
Thanks, but I already include MAC address in AP policies
03-15-2024 10:51 AM - edited 03-15-2024 10:52 AM
apart from that I connected more than 150 Ap same Model!
03-15-2024 10:59 AM
- Ref : https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
>...TAC recommends 8.5.182.7 or 8.5.182.11.
The latter being important on the 5508 as the platform is being phased out : use latest/last release available
and check again
M.
03-15-2024 11:29 AM
- You may also have a checkup of the primary controller configuration using WirelessAnalyzer input (procedure) for AireOs controllers and feed the output from that into : Wireless Config Analyzer
M.
03-23-2024 12:57 PM - edited 03-26-2024 05:00 AM
Finally, I found the issue, these AP should work with 8.5.160 and these Ap are no able to get the software from WLC, there is a way to put the ios manually? as you can see they have 8.5.131 and 8.5.161
