Re: 9800 APs, Catalyst Centre Intel Reported Errors - Invalid IE (49)
DATHOZ
Level 2
Level 2
I'm running WLC 9800-80 version 17.15.5 and client is sending this error and does disconnects from AP
Error can be seen from Catalyst Center
Reported Errors
Apr 14, 2026 10:31:19 AM
Detailed Information
Status
Report Received
Details
Type Device Analytics - Intel
APs (Invalid IEs)
Access Point: 52:68:93:BD:C3:10
BSSID: 52:68:93:BD:C3:16
Frame Type: Beacon
Error: Invalid IE (191)
Mark Elsen
    - @DATHOZ              FYI :   https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwn21361
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
CSCwn21361 is closed - Unreproducible.
@DATHOZ if you believe you can reliably reproduce the issue - and get an over the air packet capture for one or more of the offending packets, then you should open a TAC case and then TAC may re-open the bug if the OTA shows an error in the beacon from the AP.
Also keep in mind that this could just as easily be a bug in the Intel driver so:
- make sure your Intel driver is fully updated
- open a case with Intel as they might know about it already.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
