Redundancy plan being planned
aramirez
Community Member
Happy Tuesday!
Q - Is it possible to have 100 Mbs on wireless? I do not believe it, but would like to check with you all before I sign up a contract for.
Thanks in advance,
George Stefanick
Sound like you are planning a wireless backhaul ? Yes other vendors provide special frequencies and equipment that can allow up to GIG speeds actually ..
Stephen Rodriguez
100Mbps...as in?  if you are talking 802.11n/ac yes it is possible.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
George Stefanick
Let me further add. Make sure you can have them prove it as well. I've met some shady backhaul company's in the past ..
Is this vendor using Cisco gear or another vendor for the bridges ..
Here is an example
http://www.commconnect.com/gigabit-wireless-wireless-backhaul-fixed-wireless-broadband.html
