Reg: AIR-AP1832I-E-K9 Replacement
what is the direct replacement of AIR-AP1832I-E-K9?
3 Accepted Solutions
Hi Mohammed,
As Leo mentioned, 9115AX will be the replacement product for 1832 APs.
More info here:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1830-series-access-points/aironet-1830-series-access-points-eol.html
Dont forget to rate helpful posts
Rich R
Depending on your specific requirements you may also want to consider the 9105:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/datasheet-c78-744062.html
Scott Fella
Please review the link @Rich R posted.  You might want to consider a different model WiFi 6 or maybe even a WiFi 6e access point.  Look at what is there and what you think you will need that will work down the road.
-Scott
5 Replies 5
Leo Laohoo
Cisco has not yet announced the EoS/EoL date for the AIR-AP1832I-E-K9, however, the direct replacement would most likely to be the Catalyst 9115.
Cisco already announced EOL and going to be EOS in May 2022.
below is the confirmation
Hi Mohammed,
More info here:
Rich R
Scott Fella
-Scott
