Regarding problem with cisco ap
diwakar410
Level 3
Level 3
I have cisco 1700 AP. It was previously on Controller mode. Then, i changed it to standalone mode. Now, i am experiencing various problems.
1.I can't get the GUI access of AP though i can ping the ip of the AP.
2. AP doesn't broadcast the SSID.
what i noticed is the IP i set in the AP via console is shown this way:
randyinfante21
Community Member
Hi Diwakar410
Maybe the BVI is in shutdown mode. Also in the switch configuration must same subnet of native vlan and the AP
jkilleda
Level 6
Level 6
Hello Diwakar,
Add mbssid guest-mode command under the ssid configuration mode and then add mbssid command under the radio interface configuration mode.
