12-12-2022 07:31 AM
Will clicking the license reload button under smart licenses on the Catalyst 9800 cause any issues or will it just fetch the licenses again from the Cisco backend server?
Solved! Go to Solution.
12-12-2022 08:49 AM
@Maurice Ball When you click on the "Reload" under the smart license, it will present a prompt that it will reload the controller. So yes, the controller will reboot when you click that button.
12-12-2022 08:49 AM
12-12-2022 08:56 AM
it will not have any effect as per i know, as long as License already install and next server available.
12-12-2022 02:14 PM
Thanks for the info.
