02-18-2014 10:05 AM - edited 07-05-2021 12:13 AM
I need to move a controller to a new site which requires to change its name, mobility Group, RF Group name and ip address. Does anyone knows the undertakings of such a task. Tks
Sent from Cisco Technical Support Android App
Solved! Go to Solution.
02-18-2014 01:31 PM
No... Base license is permanent.
02-18-2014 12:07 PM
Well that's not as bad if you know what your doing..... if you need to keep your SSID's and other settings, then changing the hostname, ip address(s), vlans, should not be bad. You need to make sure your AP's can find the WLC, by using option 43, DNS or layer 2 broadcast forwarding.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
02-18-2014 01:10 PM
OK thank Scott But I'm sure we will be changing SSID, RF group, MOBILITY GROUP etc....is there a way to reset controller back to factory settings and not lose AP Base license information.
Sent from Cisco Technical Support Android App OK
02-18-2014 01:12 PM
Yes... You can rest it from the GUI in the command tab or from the CLI. Also when you boot up the WLC, there is a menu which you can break into and there will be a factory default there.
02-18-2014 01:26 PM
If you're going to change the lot, you might as well get it reset to factory default.
Go to CLI and enter the command "clear config".
02-18-2014 01:13 PM
Here is a link also
https://supportforums.cisco.com/docs/DOC-1639
02-18-2014 01:28 PM
OK thanks - And what will that do to my AP base license. Will I lose it?
02-18-2014 01:31 PM
02-21-2014 08:56 AM
02-21-2014 09:19 AM
Michael,
I wanted to add. If the APs on both controller will never "touch" then you shouldn't have them in the same RF and MOB group. No need to add the extra overhead to pass mobility packets ..
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
"Im like bacon, I make your wireless better"
