Error in GUI of Cisco 3850 Switch with Wireless Controller.
Ninad Thakare
I have Configured 3850 switch wireless controller. But while accessing the controller through GUI, I faced following errors while configuring it through GUI.
Because its complecated to configure it through CLI.
Attached are the snaps of error faced.
and if I didnt get this error, and able to configure, I can save it because of this error.
Please help me on this issue, so that I can easily configure the controller.
Brgds,
Ninad Thakare
7 Replies 7
Sandeep Choudhary
did you enabled the https and hhtps ?
ip http server
ip http secure-server
I would first like to confirm that everything is in place for the web interface to work properly.  Please provide me the following output from the CLI of the switch:
show run | i wsma
show run | i http
Additionally, have you attempted to configure the management through the CLI via 'wireless management interface ' ?
Hi Sandeep,
Here is the configuration which I have did.
ip http server
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
wireless mobility controller
wireless management interface Vlan4 ( Voice VLAN )
wlan FG-WiFi 1 FG-WiFi
client vlan 4
ip dhcp server 10.106.72.1
no security wpa akm dot1x
security wpa akm psk set-key ascii 0 testing1234
no security wpa wpa2
no security wpa wpa2 ciphers aes
no wmm
no shutdown
wlan GLOBALACCESSII 2 GLOBALACCESSII
client vlan 4
no wmm
no shutdown
ap group default-group
ap group 3850WLC
wlan FG-WiFi
  vlan 4
wlan GLOBALACCESSII
  vlan 4
end
Brgds,
Ninad Thakare
Try to Connect to gigabitethernet0/0 and then set the IP address.
Connect gig0/0 to your laptop and assign IP on your computer and gig0/0 in same subnet.
Then try to access: http://IP/wireless
More check here:
https://supportforums.cisco.com/docs/DOC-34542
http://mrncciew.com/2013/09/29/getting-started-with-3850/
Dont forget to rate helpful posts
Rasika Nayanajith
Hi Ninad,
3850 GUI is still not that stable, get used to CLI configuring those IOS based controllers untill GUI is rock solid.
Here are some referenceblog post related to 3850 configs
http://mrncciew.com/category/3850/
Rasika
*** Pls rate all useful responses ****
I saw the site and did my all configuration an that basis only. But now I need to configure RADIUS server group and assign it to my SSID. Which is not mentioned in the mrncciew.com site, and thats why accessing to the GUI to see the options but I am not able to see due to the above error.
BTW are reffering to the MANAGEMENT port at the back side of the switch, because I dont see any GI0/0 port on the switch.
Brgds,
Ninad
Hi Ninad,
In this post I have explained how to configure RADIUS server (used ISE as example,but it can be any RADIUS server). It should be useful if you are looking for that
http://mrncciew.com/2013/12/06/wlan-config-with-3850-part-2/
Rasika
**** Pls rate all useful responses ****
Hi Rasika,
Did what you have mentioned as well as followed the link :
http://www.cisco.com/c/en/us/support/docs/wireless/5700-series-wireless-lan-controllers/116600-config-eap-radius-00.html#anc7
But I am not able to connect and pop-up with a error -
authentication failed for client (MAC) on interface ca1 AuditSessionID
Brgds,
Ninad Thakare
