Remote AP Connecting to NAT Address instead of internal IP
Willem de Groot
Hi all,
We have a 5508 with 7.4.100.0 vor Internal APs and OEAPs.
till now every thing is ok.
Now we have to connect an AP (local) in a remote office, connected to the WLC by a VPN Tunnel.
The problem is that the AP in the remote office uses the NAT Address to connect to the WLC, so the traffic goes over the Internet, not trough the VPN Tunnel.
On the controller I have the following setting:
AP Discovery - NAT IP Only ................. Disabled
On the AP:
AP Link Latency.................................. Disabled
How to force the AP to use the internal IP Address of the WLC?
Willem
15 Replies 15
blenka
Level 3
Level 3
FlexConnect (previously known as Hybrid Remote Edge Access Point or H-REAP) is a wireless solution for
branch office and remote office deployments. It enables customers to configure and control access points in
a branch or remote office from the corporate office through a wide area network (WAN) link without deploying
a controller in each office. The FlexConnect access points can switch client data traffic locally and perform
client authentication locally when their connection to the controller is lost. When they are connected to the
controller, they can also send traffic back to the controller. In the connected mode, the FlexConnect access
point can also perform local authentication.
